Bobo Fret
- Aug 25, 2013
Turn it over, it's on the back next to Kickassium
Is amp1 able to properly drive 600ohm headphones (beyerdynamic t1 2)?
Man, the amount of effot that goes indo modding those AMP modules is quite outstanding, makes me feel quite like I'd want to try to do some of those as well
Where is the page with the mods done for the full EX?It is better if u can find a technician, and if u do it successfully, the dx208EX will leave u speechless.
Some components are very delicate and easily got damaged, due to the compact and complexity of the circuitry, once it is damaged, u can not save it
My bad, that is the same 100uf/10v Capacitor as above. The picture has been updated
Hi @Whitigir what are the 2 red things in the bottom without number marking? They meant to replace something that look look like diodes to me
Thanks, the BOM cost looks massive.My bad, that is the same 100uf/10v as above
Hmm, I can’t get the DX200 to play nice with my iPhone XR in USB DAC mode, in Android or Mango OS. It draws to much battery and the iPhone says the accessory is not supported.Not so true. DX200 (XMOS chip, actually) announces itself as a self-powered device, which is true. Then, it's up to the host driver to decide whether to provide power or not.
The funny thing is that my Android tablet, mobile device, provides up to 1A, while I'd prefer not at all. Instead, desktop computer running Windows provides only 450mA even at USB 3.0 port, and, as you said, Mac OS does not power at all
Which firmware do you use? I just tried my DX200 (1.05.036) under Windows 10. In USB DAC mode, it does not consume power.I can’t get the DX200 to play nice with my iPhone XR in USB DAC mode
