Originally posted by theaudiohobby
That is a quote from a paper that is dead set against bitstream encoding, the point of getting you to read the paper is to point out to you even the opponents of bitstream acknowledge its superiority in certain areas. |
That quote is also only relevant to the 'alternative bitstream converter' and we have no idea whether such an alternative is being employed. The 'advantages' in that quote also happen to be that this methodology solves inherent problems in DSD that were never present in PCM to begin with!
The DCS papers infer that DSD in controlled listening conditions is superior to 192/24 and secondly that time resolution is proportional to sampling frequency. |
That's a flat
lie. This is all that had been said about DSD in the paper:
44.1 kS/s, 16 bit (current format)
96 kS/s, 24 bit · much less “busy signal” break up – very good quality
· better separation of reverberation/room acoustics from instrument
output
· bass better balanced
· percussion (particularly cymbals) better
· some stereo image formation
192 kS/s, 24 bit · no “busy signal” break up – excellent quality
· very good separation of reverberation/room acoustics from instrument
output
· but - bass can appear light and slightly out of time
· and - stereo image can be strong but widened (1.5 times?)
DSD · detailed comparisons not yet performed on enough systems, but well
liked by (classical) artists after sessions
· very good separation of reverberation and room acoustics
· no observations on bass so far
· strong stereo image formation, no observations on width so far
When played back on a system with adequate hf tolerance, the results from DSD are very good. We have not so far done enough comparative listening tests (DSD vs PCM or DSD vs Analogue) to
comment usefully on the differences. We have done some testing of different filters in the noise shaping loop in a DSD modulator. However, even these results are dependent on the monitoring
system and useful comments cannot be made at this stage. |
They explicitly stated that no useful comparisons between DSD and the PCM formats! As I said before, where deficiencies in 192/24 were noted, no corresponding observations had even been made about DSD! 'Time resolution is proportional to sampling frequency'? Where did they say anything like that?
As I consistently said in this thread, I am yet to read anywhere that anybody has disputed the superiority of DSD time resolution over 192/24. |
And *I* have yet to read anywhere that anybody has stated DSD time resolution to be better than 192/24! So what if nobody spoke against a claim, if that claim had never been made in the first place!
Now that you have read that I think it is time to read response . The conclusions are clear that infact SACD is more bit efficient than DVDA and has better time resolution and has a more linear response for a given input. The second paper discusses issues of transient response that is key to understanding DSD's superiority over DVDA and one of the key reasons why slowly but surely DSD is pulling away from DVDA. |
1. There is only one link here, to the content page. I assume the first article I'm supposed to be looking at is 'SACD Format: Development of the DSD Recording Solution'. Where's the second? Or is this the second?
2. Stop putting words into people's mouths (or paper's mouths in this case) This article may have vaguely implied at the start that the Augan-dCS recorder sounds better than the rest of the equipment there (...of which there are 3 DSD systems and only 1 24/96 (not 24/192) PCM system. Way to go, beating 3 of your own kind and 1 weak representative from the other camp!) but the rest of the article is just a chain of mumbo jumbo about how hard it was to develop a proper DSD recording and mixing system. It never explicitly talked about the relative merits of DSD and PCM anywhere, certainly not from a technical point of view. Bit efficient, better time resolution, blah blah blah--you're making it all up.
There is more to music than just bit resolution and that realisation is what is finally causing digital to pull away from vinyl based systems. One thing that a digital system should have over vinyl based systems is precision, however if your precision is focused on the wrong parameters, then you will have missed the mark by a long shot and I submit to you that SACD has made the right choice but choosing to preserve time resolution over its useful bandwidth. |
By the Nyquist theorem, time resolution can be converted to frequency resolution. A system with higher time resolution must respond to higher frequencies.
Here are the frequency resolution figures for DVD-A and SACD:
DVD-A 24/96: 0-48kHz, (0-96kHz for 24/192) 144dB dynamic range across the entire range
SACD DSD: 0-100kHz (approx), 120dB dynamic range at lower frequencies, down to virtually nothing at higher frequencies (where everything is swamped by noise) |
(Here's the
source. It's a thread where I am actually floundering about for an explanation to DSD. If you doubt the claims above, you can post a question in that forum, where there are much more knowledgeable people than you or I)
Things to note:
1. SACD has lower dynamic range than 24/96 or 24/192 across
the entire frequency spectrum it covers
2. SACD's frequency response range does *not* got up to 1.4MHz, as the 2.8MHz sampling rate may suggest. This is because of the noise shaping necessary to obtain acceptable dynamic range in the audible frequency range. Without noise shaping, the frequency response would be up to 1.4MHz, but the dynamic range would be only 6dB for the whole range!!
3. 24/192 can cover up to 96kHz with 144dB (i.e. 24bit resolution), while SACD would be close to 0dB at this point! The only advantage SACD has is that it responds to some frequencies beyond 96kHz, up to maybe a bit over 100kHz, but with the dynamic range closing to 0dB.
Translating this into time resolution: DVD-A can encode sonic events with cycling period > 1.04167e-5 seconds with 144dB of separation from background noise. SACD, in encoding a sonic event with cycling period close to 1.04167e-5 seconds, will give you an output that is barely distinguishable from the background noise!
Just to put this in perspective, our ear's time resolution only goes up to events with speeds up to a rate corresponding to ~20kHz (maybe higher for those with bat ears, but certainly not above 48kHz!), the frequency ceiling of our hearing. There are exceptional cases with transients and interaural time differences where we can respond to faster events, but any format that can record up to and beyond the frequency ceiling of our hearing can also encode these transients and ITDs perfectly.
Here. *I* dispute the superiority of DSD time resolution over 192/24!
As outlined above I say it is worse
If you've read so much stuff that supports its superiority in this regard, maybe you can post some stuff to defend this. Heck, if you are so tech-savvy, maybe you can tell us what's wrong with that article somebody posted here that says SACD can't encode anything above 8000Hz correctly!
