Thanks for the kind comments - you've given us a lot!!
I mostly agree with you and understand the impression that the 6J6 gives a better bass slam, but you are correct that they are a little "harsh." That's because the distortion is a bit higher and you'll hear it on loud and elevated multi-voice passages. I've also purchased the Mullard CV4031's that you've recommended, but I'm not certain that they're that much better than a good Sonotone 6J6W or similar.
That's only my opinion, though. I have some ECC960's but have not got around to trying them, yet. One other tube that people might try as a somewhat cheaper alternative to the E90CC is the E92CC. It's almost an identical tube with slightly different ratings.
It has a tad bit more distortion than the E90CC, but is still in a much better class than the 6J6.
That said, a little perspective is perhaps in order: even with the 6J6, the sound quality far surpasses other tube amps in its price range. Realize that the 6J6 is still available for $1 (ESRC Tubes until tomorrow!) or a bit more at most places. This final rendition of the Torpedo has taken some time and a lot of work from Dsavitsk - even Morgan Jones and Kevin Gilmore helped along the way to pinpoint/solve the noise issue.
As a result, I can finally brag: the Torpedo is truly one of the finest tube amplifiers available. The fact that it's available in PCB form as a DIY kit makes it even more valuable and unique, IMHO.
Anyway, I know I'm a MOT, so my motives and opinions are supposedly questionable and biased, but still ... it's wonderfully exciting to be able to supply something from Beezar that performs at this level of quality.
