Mark Up
Thanks for this. Please investigate the NVX Standard (non angled) Pleather pads. A link is below. These are so much like leather vs. other simulated leather pads (like Brainwavz). They are softer than Brainwavz famous HM5 pleather or real leather or velour pads AND have a larger opening. These are my favorite, most comfortable pads. Only $20 at the link below or on Amazon. Also, Monoprice just started selling pads very similar to this (not quite as thick, close, but it's their only disadvantage) for only $10. Same great soft, realistic, fake leather, same large opening. Pads like the NVX Standard - or, one with a bit more padding would probably put these headphones over the top. The existing pads are about as soft as they are, but like the OPPO pads, don't have enough inner foam to stop compression so your drivers touch the insides. I've got above average ears in top to bottom length, but they are average to flat against my head, so if MY ears touch the driver, there is no hope with someone with the kind of ears that stick way out either. Of course if you test them and they ruin the sound, they won't work.Re Padding, we're adding a layer of very squishy, perforated foam padding in the headband. Re Extension, we're extending the range by 1-2 clicks The team has been working day and night to incorporate these changes while maintaining our fulfillment schedule.
https://nvx.com/xre100s-comfortmax-standard-cushions
