Hi all. Thanks for this thread and the great recommendations. I purchased the Douk Audio U2 PRO, and it has been great feeding my Chord Mojo via optical. I'm using the Windows 10 built in UAC2 driver, which works great with Tidal HiFi in exclusive mode. The Mojo is so much more stable now and less subject to EMI interference and random shutoffs. I think sound quality is quite improved as well. (Of course I didn't do double blind A/B tests--but playing like it should versus frequently pausing the music/disappearing from device manager is objectively and measurably a heckuvalot of sonic improvement in any event
Here's my question. In Exclusive Mode, the Windows mixer is disabled as it should be. I don't see the animated levels going up and down in Windows Volume Mixer, and no other apps or browsers can play sound to this device while Tidal is playing. But why does the Windows volume fader still work to control the sound level? I see the Mojo's glowing orb is the correct color for the Tidal stream's sample rate (as opposed to the color it glows for Windows system sample rate), even if I lower the volume with the Windows slider. Is this UAC2 hardware volume control--i.e., Windows telling the Douk over USB to lower the volume? I don't see hardware volume control feature listed anywhere on on the doukaudio webpage. If so, it's still bit-perfect even when volume-lowered through the Windows slider, right? Thanks.
