Godot
- Nov 15, 2012
So, I've recently bought VSonic VC02 IEMs on account of what I read about them and other IEMs here, and while I'm satisfied with them I'm now thinking that I might upgrade my old Sennheiser HD201 to something better as well (seems like you've successfully infected me too). I'm looking for natural sounding, detailed, articulated, resolving closed circumaural headphones.
Here's the problem though; I live in a small European country and for multitude of reasons prices of most new headphones here are quite inflated when compared to the prices in US, so it's harder to find a decent deal on mid-fi headphones. Currently though, I have an opportunity to buy like new AKG K272 HD (for around $140) or brand new Beyerdynamic DT 770 PRO, 250 ohm (around $150) so I was wondering if someone might help me decide which one to buy? I've read countless reviews of said headphones but can't make the final decision. Here are some of my conclusions, my synthesis of reviews and opinions I've read on those headphones.
But first, the "What I'll be listening to mostly" list:
- FLAC files from my PC (Xonar DG + I'm considering buying a dedicated amp as well), possibly V0 MP3 from a portable player (Clip+) after I buy a portable amp.
- Jazz (everything from swing to free jazz; only thing I don't really listen to is smooth jazz and similar)
- Prog rock
- Classical (Don't care much for operas, operettas and similar but am interested in almost everything else)
- some classical rock (stuff like Beatles, Moody Blues, Procol Harum, Deep Purple, Who, Doors and similar. Mostly sort of proto-prog stuff I guess)
- I will occasionally listen to other types of music as well but aforementioned stuff is what I'll listen to most
- also I'd use them for movies (somewhat important) and occasional gaming (less important). Probably with Dolby Headphone. So it would be nice to know which one performs better with movies and video games as well.
Now what I gathered about the headphones in question so far:
AKG K 272 HD
- consumer orientated siblings of K 271 MK II
- can run unamped, however amp is recommended if one wants to fully utilize its capabilities
- clear, detailed and resolving
- somewhat lacking in bass (might be improvable with good amp?)
- unmatched mids in its price range
- midrange - not sure, opinions seem to be to diverse to make a sensible conclusion
- should be well suited for jazz and classical music
- decent soundstage for closed headphones in it's price range
- mediocre isolation
- great comfortability
- not really suited for portable use
- questionable construction quality
Beyerdynamic DT 770 PRO, 250 Ohm
- 250 Ohm version of Beyerdynamic's well regarded DT 770 series
- amp is a must
- might be a bit to bassy, even though they're supposedly significantly less bassy then 80 Ohm version, however the bass is well defined
- somewhat recessed midrange according to some (certainly not as detailed as K 272 HD)
- extended and well defined treble
- generally considered comfortable (but K 272 HD should be more comfortable)
- not really suited for portable use (although they might be a bit better suited for it than K 272 HD)
- better construction than K 272 HD
- might be better suited for immersive gaming and movies than K 272 HD
The bottom line is; I'm afraid DT 770 might be a bit to bassy for my taste, while K272 might be a bit lacking in bass. I guess I'd like an overall more balanced sound from my headphones...
Also, I doubt anybody actually uses either of these headphones in their portable setup? Even though both are closed, given the fact that neither of them is collapsible and they have long nondetachable cables, I'd guess it would be quite inconvenient to carry them around?
Some other potential options (which I could order for a reasonable price from abroad) and which I'm willing to consider, provided they're closer to the sound signature I'm looking for and under $150, include:
- Fostex Audio T50RP (I know these are semi-open (or is it semi-closed?
- Audio-Technica ATH-M50
- Brainwavz HM5
- Sony MDR-V6
- Superlux HD660, HD662 F/B, 669
- Shure SRH440
Any help would be appreciated. Thank you.
- Prog rock
AKG K 272 HD
- amp is a must
- Brainwavz HM5
- Sony MDR-V6
- Shure SRH440
