Just give me a couple of days. I'll build you what you want.
Any color preferences?
Diamond cladded ones look good. I can wear them around my neck. Said to improve SQ through extensive EM rejection =)
The day that someone buys and says they can tell the difference between an "audiophile" SATA cable and a standard one is the day I leave the audiophile community.
The difference is extremely minimal. Any of these "micro" differences is probably induced by the tolerance of the analog circuitry. Please mind the signal is DA-AD and passes through the analog domain. There is a lot of (pro) gear out there which won't give you such a clear "matching" result on 2 measurements, even when taken under identical circumstances.
Bye...I hardly even knew you.
http://www.ar15.com/archive/topic.html?b=1&f=5&t=1080432
And here, the same guy says it again:
http://www.malcolmsteward.co.uk/?p=2495#comments
Original one has been removed....for obvious reasons.
This guy makes my day everytime.
/putting words into other peoples mouths, as usual.
http://www.malcolmsteward.co.uk/?p=2534
ETA: I think Mr. Steward is an idiot.
Hmm describing the improvement in sound about a certain area and then asking the listener to listen for it might introduce the potential effect of placebo upon a listener =)
Up till the point of the USB module on your motherboard, everything has digital error correction so there is no need for 'good' or 'snake-oil' cables used in between.
Mmm don't DACs come with error correction built into the USB protocol? It can't be that we're paying good money for something that can't even do that?
Those links are shocking. It really is very difficult to have a proper evidenced discussion about cables, but to get a death threat??????!!!!
and yet you are.
>Will better cables do error correction for us or prevent errors?
no, very unlikely unless your stock cable is not to spec.
>I think it has been mentioned many times in this thread that there is no error correction for USB audio because it is different from other USB appliances.
