dvw
- Mar 29, 2002
Gold is 24% less conductive than copper.... Only used in electronics because there's no rusting or tarnish.. It is effective at preserving contact integrity, and the gold plating is ludocrisly cheap. Your fears should not be any threat to electronics manufacturers for a couple more thousands of dollars/once. Gold plating is that cheap to use.
Have you ever seen an electronic employ gold wiring?
You/I probably never will.
Yes and plenty. Most silicon chip are wired to their package with gold wire. I am in the middle of qualifying copper wire to replace gold wire. The concern is not conductivity but more for reliability. How well does copper wire stay on? With silicon manufacturing, wire are not soldered but thermally bonded. There are a lot of silicon already converted to copper wiring. So in theory someone will be able to tell their amp or DAC are made from copper or gold if material makes a different in sound even in digital connection.
