Hase
- Dec 14, 2004
What pins are we connecting on either side of the 66k-68k resistor?
15 + 11 --> resistor --> 21 ?
Originally Posted by Hase /img/forum/go_quote.gif What pins are we connecting on either side of the 66k-68k resistor? 15 + 11 --> resistor --> 21 ? |
Originally Posted by ruZZ.il /img/forum/go_quote.gif 'tying' reffers to coupling the signal. in this case, it means making an electrical connection, or soldering a piece of wire between 2 points to 'short' them together. If you go through the last few pages of this thread, take a look at some of the pics peoople have posted, and the schematics of sorts, you should get the idea. You'll see that on top of hooking up Left, Right and Ground signals in the LOD, you also have to hook up a resistor in between some pins in order to let the ipod touch / iphone know that you want to hook up an audio device. |
Originally Posted by lucifix /img/forum/go_quote.gif Thanks for the reply! ![]() Is it a must to connect a resistor? I am getting the really small dock connector ![]() Can I just use a wire to connect the two points? Lastly may I confirm that the ground wires to connect are 30&11, and 30&21? |
