analogbox
- Jun 26, 2007
Even if you have quality gears, there's no guarentee that it will sound exactly the way it was recorded. Using EQ will simply help you, to a certain extend, get better frequency response on your headphones weak area. Of course, if you use it to much it will ruin the sound as well as your listening experience but if it's used properly it can make some phones better than what they actually are. I don't use it on my high-end cans since they are super sensitive on eqs and I don't wanna bother with it but I do use it on my lower-end cans or earphones since most of them have colored sound and needs tweaks to sound acceptable.
Originally Posted by worldman /img/forum/go_quote.gif Simply put, if you have quality gear and source, you do not and should not use EQ to intentionally ruin the original recording. However, to ruin or not, that totally is up to the listener to choose. Personally, I do not ever use EQ. |
