There was a simple question how digital audio could be influenced.You try stuff, casually, you feel a change, and you talk about jitter....
As simple as that.
Cheers!
You’ve got that backwards. The studies were intended to establish the thresholds of audibility of jitter. They weren’t studies based on consumer equipment. Jitter levels in consumer equipment is measured all the time, and I’ve never seen any measurement that came close to being audible. As I said before. Measured jitter in home audio components generally falls far below the established thresholds… usually by an order of magnitude. If you know of some product with audible levels of jitter, let me know.Nope... don't have one either.
Well then, this is also settled -- some studies about jitter, done at a time in place, done maybe decades ago, with certain equipment, certain people, revealed that jitter was not an issue in the sense of statistical relevance within that testing setup.
This does IMHO not rule out the possibility that other equipment, in other circumstances, behaves differently.
Its not broken, but its, as mentioned in the measurement, not good either.Well...
... on an abstract level.
Still, there's various degrees of measured jitter in USB audio, see the measurements published by Golden One.
Link to some MA3 DAC below, others easily found on his website.
How come, if everything's perfect and "The timing of sending data asynchronously can not have an influence on the timing of digital to analog conversion in any way at all"?
(and NO, it's not broken)
https://goldensound.audio/2024/06/08/meitner-ma3-dac-measurements/
Thanks for that link!...
http://www.nanophon.com/audio/1394_sampling_jitter.pdf (cited in section 2.2)
This is a valid point of viewIts not broken, but its, as mentioned in the measurement, not good either.
No, not at all.I am probably annoying the hell out of you,...
It’s been known for a very long time, back in the 1950’s in fact and actively attenuated since around 1952. And incidentally, you’ve effectively cited marketing from 30 years ago, not long after the falsehood of jitter being an audible problem in consumer DACs was first invented by audiophile marketers.No idea about Linux kernels (other than they exist).
General problem with digital audio is timing issues AKA jitter.
https://www.stereophile.com/content/jitterbuggin
... has been known for quite some time it seems.
It is of course impossible to have perfect timing, we can measure timing down to thousandth’s of a trillionth of a second, so at that level we can always measure some timing difference in pretty much anything, even in the speed of light over relatively short distances. So it should be obvious that is not the issue, the actual issue is, as it always is; does this measured difference even have any effect on the sound being reproduced and only if the answer is “yes” can we even ask the question; does it reach the threshold of audibility?Another disclaimer: I am NOT an electronics engineer. Nor DAC designer.
That having said: Even with asynchronous transfer of data (USB) from source to DAC, some sort of timing alignment HAS to happen.
Again, jitter has been known about and researched for over 70 years. The first study published publicly that I’m aware of was done by the BBC and published in 1974, half a century ago. Its conclusion that jitter below about 200ns (billionths of a second) is inaudible with music recordings has been confirmed by numerous subsequent studies. To my knowledge, there has never been any consumer DACs with jitter anywhere near that bad, even going back to the first generation of CD players 40 years ago. By about 35 years ago, the cheapest, poorest quality DACs available on the market had jitter less than 2ns and by the mid 1990’s, even cheap OEM CD drives typically had jitter in the region of 200ps (trillionths of a second), so around 1,000 times below audibility!Well then, this is also settled -- some studies about jitter, done at a time in place, done maybe decades ago, with certain equipment, certain people, revealed that jitter was not an issue in the sense of statistical relevance within that testing setup.
Yes, again we can measure jitter down to stupendously tiny levels and the example you’ve cited is a good one. The jitter artefacts are around -140dB to -160dB and to put that into the perspective which you don’t appear to appreciate, that’s roughly 33 to over 300 times (respectively) below the threshold that sound can even exist in air (assuming a peak playback level of 85dBSPL). So obviously, any question of audibility is moot, because regardless of the hearing threshold you cannot hear a sound that cannot be reproduced and therefore does not exist!Still, there's various degrees of measured jitter in USB audio, see the measurements published by Golden One.
Why jitter and not literary anything else? Everything influences anything else, pushes some molecules, grabs one electron, then the dog pukes on the carpet(the butter knife effect or something, I'm not a meteorologist).There was a simple question how digital audio could be influenced.
As simple as that.
Cheers!
Hm... noise and jitter. But from a technical point of view: Good question! What else (besides the bad "j"-thing) could detoriate a DAC's sound quality.Why jitter and not literary anything else?...
Naa... spare the poor creature's life! There's better ways to improve soundstage.I'm genuinely curious. Should I sacrifice a goat for better soundstage?
But the example of jitter you gave could not “deteriorate” or in anyway affect a DAC’s sound quality, not unless you change the laws of physics!But from a technical point of view: Good question! What else (besides the bad "j"-thing) could detoriate a DAC's sound quality.
Lots of interesting details. Had a brief 10 minutes read and will continue on the rainy Sunday...
Thanks again!![]()
Two big contributing factors are noise and jitter (somehow interrelated) on the digital signal line. And no, also USB is not bullet-proof, even with non-defective devices.
Basically there is only one thing an DAC can do wrong, not outputting the sound wave we want.Hm... noise and jitter. But from a technical point of view: Good question! What else (besides the bad "j"-thing) could detoriate a DAC's sound quality.
The tl;dr Version^^Frequency, amplitude and time.
Well...
