olblueyez
Banned
- Jun 16, 2008
Sorry Nick, that sounds terrible, I know your a decent fellow, I should have said im not willing to use this for a few weeks.
Originally Posted by KevM2 /img/forum/go_quote.gif As has been said before, some of these cable manufacturers have a 30 day return policy, so it's up to you to audition them and get your money back if you aren't pleased with them. If you ask nicely enough, they may just allow you to audition them without 'purchasing' them first. To be honest, I don't really have a desire to record music and run it through a spectrum analyzer or whatever elaborate process will convince people that I'm not fibbing, especially when there's an option to test with your own ears for basically the cost of shipping and a 'hold' on your funds if you don't like them. The difference in sound quality between interconnects is definitely noticeable to my ears. Will it be as mindblowing as jumping up to some expensive new amp? Probably not. Anyhow, the biggest difference in sound will come from going from one metal to another. Try silver if you have copper and vice versa. Copper is heavier sounding (more focus on bass), with everything having more weight. Silver is generally leaner and faster with more of a treble focus. Now, I'm not here to win converts and to sway the unswayable and lead the flock into the land of interconnect bliss. I'm just posting impressions based upon my own experience. If you want to do a cheap test, although they are not interconnects, you can experience the difference of a cable's effect on sound. If you have an HD600 or HD650, order the other cable for your phones. For example, if you have HD600, order the 650 cables. If you can notice the difference in sound quality between the two relatively cheap cables, then that'll give you some hint of what cabling can do. If you can't, you might as well just not worry about it and just keep your money in your pocket. |
Originally Posted by olblueyez /img/forum/go_quote.gif [Why do you think Skylab wont write about amps he hasnt had a chance take home and spend time with? |
Originally Posted by Currawong /img/forum/go_quote.gif nick_charles: While I appreciate the idea of your experiment, frequency response differences wont indicate why some cables allow more detail in music to be revealed, and some less. |
Possibly what's needed is a measurement of frequency of frequency changes when different cables are plugged in, with the same music. |
Originally Posted by olblueyez /img/forum/go_quote.gif Sorry Nick, that sounds terrible, I know your a decent fellow, I should have said im not willing to use this for a few weeks. |
Originally Posted by nick_charles /img/forum/go_quote.gif Then how does one operationalize detail ? If it is not an accurate rendering of the frequencies and intensities in the recording I am not quite sure what else it could be ? Sorry I will have to ask you to explain this. A cable has a certain frequency response that is measurable and as far as I am aware under a given set of circumstances quite consistent. Unless there is bizarre impedance matching issues with the amp (such as some NAIMs) the behavior will be consistent. |
Originally Posted by olblueyez /img/forum/go_quote.gif Using your ears has always been the answer. |
Originally Posted by nick_charles /img/forum/go_quote.gif But what does more or less detailed mean ?. It just seems like a vague statement that cannot be the same for any two persons. If you say cable A is more detailed than cable B but somebody else with equivalent hearing and experience says the opposite is true then where does that leave us ? PS what cables do you use ? |
Originally Posted by olblueyez /img/forum/go_quote.gif It means you can listen to "Sinatra Live at the Sands" and hear silverware tapping a plate in the background during the monologue. Not something you will hear with an iPod or a low end amp. A nicer cable can make the music much more resolute. |
