The fact is silver plated OFC copper is more costly and complex to incorporate into your lineup than using the same cable you use for all your other phones. The accountants at Sennheiser would say one of three things:
1-the cable makes no audible difference, use the same cheaper cable.Since they do use it, we can rule that out.
2-the cable does do something according to the engineers, so use it.
3-marketing the more expensive cable will yield greater profits over the greater costs of incorporating it.
You can email their accountants and let us know about their reply
