MacTheCat
- Jul 5, 2005
PartsExpress has a fairly large gallery of projects to look through. I am thinking of building 5 of these for my soon to be home theater.
Originally Posted by Garbz /img/forum/go_quote.gif Correct me if i'm wrong but dipoles have the bass drivers surrounding the tweeters not the tweeter on top so that everything appears to come from a co-herent point? Mind you I think that definition changes depending on how the theory of it is applied. How is your design dipole? |
Originally Posted by rayq /img/forum/go_quote.gif How about ProAc Response 2.5 clone (http://www.geocities.com/diyproac25/links.htm)? I listened to the original one and loved it but it costs $6500 CAD, ouch! |
Originally Posted by Wodgy /img/forum/go_quote.gif No, the idea that back ported speakers are harder to place is a common misconception. It stems from people actually putting the speakers right up against a wall, which obviously does block the port. If there's adequate airflow, however, it makes no difference. All speakers sound better away from room boundaries, but again, you can reduce the baffle step compensation if you really do want speakers to go in a tight space right up against a wall. Back ported speakers also have the advantage of reduced midrange leakage towards the front (bass frequencies wrap around the cabinet because they have a longer wavelength). The first layout you gave would work. You may get a slightly more bass heavy sound from the left speaker and a slightly more uneven midrange from the wall reflection, but the advantage of being able to listen from your desk sounds like a worthwhile tradeoff to me. No one has a perfect room. It looks like you'll have adequate space behind each speaker. |
Originally Posted by MacTheCat /img/forum/go_quote.gif PartsExpress has a fairly large gallery of projects to look through. I am thinking of building 5 of these for my soon to be home theater. |
Originally Posted by Chops /img/forum/go_quote.gif Speaking of speaker projects and going for somewhat different, one-off designs, here's my next project, hopefully before the year's end. It's an Open Baffle (dipole) design utilizing two 15" high efficiency drivers per channel and an Altec 511B/902-8B horn/driver combo. It will be bi-amped and should be right around 102-105dB @ 1W/1M. If you haven't tried a dipole design before, then you don't know what you're missing. Think of it as open-cans vs closed-cans. |
Originally Posted by Garbz /img/forum/go_quote.gif Correct me if i'm wrong but dipoles have the bass drivers surrounding the tweeters not the tweeter on top so that everything appears to come from a co-herent point? ? |
Originally Posted by Wodgy /img/forum/go_quote.gif Unfortunately, it's not a good idea to build the "Totally Tubular" design horizontally as you've pictured it. The Tubular is an MTM, and due to the phase interaction of the two woofers, the off-axis response of an MTM along its longest dimension is quite poor. Here's a graph showing the lobing behavior of two MTM woofers, no crossover (this is obviously the worst case, but it illustrates the principle): In general, lobing in the vertical direction is not a large problem, because the range of locations where people's heads can be vertically is small, plus the ceiling is far away. On the other hand, you want to make the horizontal off-axis behavior as flat as possible, not just so that you can move around the room and have the sound be the same, but also because you want the reflections off walls to be similar in character to the main sound. To be honest, I'm quite skeptical about the off-axis behavior of the Tubular design even as specified. There are no off-axis measurements and so it's impossible to quantify the effects of baffle diffraction, but at least the project isn't that expensive so it's not a huge risk to build it and try. But I would build it vertically as specified, not horizonally. |
Originally Posted by blip /img/forum/go_quote.gif Chops is right. What you are thinking of are coaxial speakers. Anyway, glad to see that you are going with the tubular concept. Those things look amazing! But I'm a bit worried about using PVC. It seems like PVC resonates very differently from wood... I wonder how that will effect the sound? I suppose you can always dampen it down if necessary. As for building a woofer into the base, it should be do-able. In fact I think I saw a similar design a few days ago.... Ahhh... here it is: http://zaphaudio.com/BAMTM-2.00-MTM-Sub.pdf |
Originally Posted by digitalmind /img/forum/go_quote.gif They do look amazing but I also don't really like that they use PVC. Still, it'll be fairly easy to make and easy to tweak if there is resonation. Nice link, definitely an interesting design. I know that bass tones are non/less directional than other sound frequencies, but is there a reason why some (mostly high end) speakers have the woofers firing sideways? I can understand downfiring, rear firing, and front firing, but what's the advantage of having the woofer fire sideways? Here's what I'm looking at now: http://xs.to/xs.php?h=xs110&d=06486&f=iso.png http://xs.to/xs.php?h=xs110&d=06486&f=left.png http://xs.to/xs.php?h=xs110&d=06486&f=front.png |
Originally Posted by Wodgy /img/forum/go_quote.gif PVC tubes actually aren't a problem. Cylinders have a strong physical resistance to radial expansion and are fairly immune to resonance, much moreso than boxes (except for the one potential resonance along their length). See Linkwitz' remarks about that here: http://www.linkwitzlab.com/Pluto/construction.htm also, just generally, it's worth taking a look at the Pluto and Pluto+ designs: http://www.linkwitzlab.com/Pluto/intro.htm http://www.linkwitzlab.com/Pluto/subwoofer.htm People use side-firing woofers because of convenience, mostly. It lets you have a cabinet with a slim front baffle and yet still have a relatively large woofer. Also, not all sub drivers are suitable for being used in a down-firing configuration. You can find how to do the math for suitability of down-firing drivers on Parts Express' site. |
Originally Posted by ooheadsoo /img/forum/go_quote.gif Not to mention the school of thought that says the less re-radiation of sound from the baffle, the better the imaging. |
Originally Posted by Uncle Erik /img/forum/go_quote.gif Have you considered taking a conventional design and then building a second, more exotic cabinet around it? Or does the unusual shape have to be functional, as well? Personally, I'm a big fan of the ProAc 2.5 clone (not perfect, but damn good for the price and effort) and while it's a simple box, there's little reason you couldn't dress up the exterior with cutouts and/or interesting stands. Either that, or you could pick up some exotic, figured veneer and do something interesting with a basic shape. |
Originally Posted by pne /img/forum/go_quote.gif theres no need to rip of the gallo reference speakers.... |
