Wodgy
- Feb 24, 2002
Your design looks great. The nice thing about DIY is that you'll likely end up with a much better sounding speaker than the Gallos (an underwhelming speaker, despite the price).
Originally Posted by Garbz /img/forum/go_quote.gif Correct me if i'm wrong but dipoles have the bass drivers surrounding the tweeters not the tweeter on top so that everything appears to come from a co-herent point? Mind you I think that definition changes depending on how the theory of it is applied. How is your design dipole? |
Originally Posted by dcheming /img/forum/go_quote.gif Selah Audio has a lot of nice kits: http://www.selahaudio.com/ |
Originally Posted by dcheming /img/forum/go_quote.gif There's also the high performance "Ariel" from: http://www.nutshellhifi.com/Ariel.html |
Originally Posted by ezkcdude /img/forum/go_quote.gif For a first project, I do not recommend building anything other than a conventional 2-way box design. As for dimensions, use the "golden ratio" (with the width being the smallest dimension). Keep the crossover simple. I had mine designed by Madisound (using the LEAP software). Make sure to use bracing and remember, the heavier the box, the better. My speakers were made of 3/4" MDF and 1/4" plywood veneer. They are dense, and sound great. I'm still using them after 8 years. Unfortunately, some of the drivers I used are not readily available anymore, like the Focal inverted titanium dome tweeter and Audax aerogel woofers. You can still get Scan-Speak drivers, which I highly recommend. Stick with a simple design, use high-quality drivers, build a beastly box, and you will get great sound. |
Originally Posted by Blooze /img/forum/go_quote.gif May I suggest Pi Speakers for kits. They sell all the electronics for each speaker and then you build the cabinets. Wayne will email you the plans anytime to look at, just ask. http://audioroundtable.com/PiSpeakers/ I have heard many of his designs through both SS amps, high power PP tube amps, and low power SET's. I personally run a 0.9W 12B4 SET into a pair of Pi Two Towers. It's plenty loud. If I put my NAD Bee amp into them it will knock things off the wall and the amp starts to turn on it's soft clip feature before the speakers distort. http://www.pedalforroses.homestead.com/Speakers.html Another thing, several on Wayne's forum are working on a low cost, entry level line array that is supposedly sounding very good. These will be able to be built for about $350/pr. I plan on trying them out. http://audioroundtable.com/GroupBuild/ As mentioned above, Selah makes some fantastic designs. I've heard Jim Griffon's Array's through a digital xover and they are the best speakers I've ever encountered. http://www.lonestaraudiofest.com/photos2.html http://audioroundtable.com/ArraySpeakers/ |
Originally Posted by FallenAngel Check out this site, I was recently interested in DIYing some speakers as well but certain circumstances (aka girlfriend's 3" heels hovering way too close to my balls) have persuaded me to hold off for a little bit. |
