cdacosta
In my previous residence it was a new build. I had two 20 amp dedicated lines run from the panel to the listening room. Although the power was cleaner, only now I realize that even those runs would act like an antenna. Also realizing now that since the dedicated line breakers are next to the other breakers in the panel, they would pick up noise from the other breakers for the rest of the home.Just thought l should share some information, to back up the antenna theory.
l have been a long distance radio listener for 30 years, based in the UK, when conditions we good, you can hear MW stations from the USA and Canada etc.
When the Internet started to become bigger, companies where using PLT, that's Power Lines Transmission that basically uses your household sockets to transmit data from one socket to another. There was a massive campaign against these from the world of radio, mainly Radio Hams, as this PLT boxes where not filtered, and would cause interference from LW to Shortwave, and in a nut shell, all your houses AC wires would act like a giant antenna, radiating RFI.
l happened to have a next door neighbour who had PLT, he was totally unaware of the interference, and thankfully, he turned the units off during the night, so l could continue my hobby.
l actually conducted a test, using a portable radio, l could still here the noise,although weaker up the a quarter of a mile away!
And for myself,this backs up cdacosta giant antenna theory. There's no sheilding in the wiring in UK houses, your only find it on the run up to your power breaker,as it tends to be armoured.
Thankfully, the UK isp companies have moved away from PLT, and its more wireless extenders are offered.
Anyway just thought l'd share my experience, and it dies has parallels with the giant antenna theory.
Understanding better how this all really works and effects the performance in my audio system is very cool. Giving me more ideas as to how to further improve upon lowering noise at junction points we can easily access across AC wiring acting as an antenna. I shared the DIY post so others can experience the immense sonic benefits from lowering the EMI noise along our AC wiring. Appreciate that you shared your experience.
