DIY Earbuds
Aug 18, 2021 at 4:13 AM Post #3,886 of 4,718
They are easy to make because you use only the half of the cable. Tricky part is to put paracord in the shell stem.
No, these are the ShoonTH buds https://penonaudio.com/ShoonTH
On thick paracord it not hard, but with thin one it's annoying and time-consuming
For ShoonTH buds, I don't know if they used paracord or snake skin (similar to shrink tube but more flexible)
Aug 18, 2021 at 4:16 AM Post #3,887 of 4,718
Aug 19, 2021 at 9:15 PM Post #3,889 of 4,718
Well, crap. I was trying to prep my spare set of 150Ω red film drivers and found they were a bit overzealous with the glue on one. :rage:
It peeled part of the red film on removal. :sob:
Aug 20, 2021 at 5:53 PM Post #3,890 of 4,718
I finally managed to buy a pair of Nokia HDD-1 and you show me this :tired_face:.
Any tips to prevent this from happening?
On a side note i also pulled the trigger on these new drivers: https://www.aliexpress.com/item/1005003104504698.html?spm=a2g0s.9042311.0.0.70c64c4dw2zZvM
There are no infos or reviews but i found this weird graph from another seller.
I usually expect lots of bass from a titanium composite driver but the graph suggests otherwise.
We'll see...
Aug 20, 2021 at 8:41 PM Post #3,891 of 4,718
Oh, I'm going beyond the normal build and was removing the drivers from the original covers.
If you are just popping the drivers & covers off to re-cable and/or tune them, you shouldn't have an issue.
Aug 21, 2021 at 5:48 PM Post #3,892 of 4,718
I had bad luck too with removing covers, so last time when I wanted to remove an original I sacrificed it by cutting up the side to 2mm pieces and peeled it off.
It is better than a broken driver.
Aug 21, 2021 at 5:54 PM Post #3,893 of 4,718
We'll see...
Why did You choose that if You feel the graph is weird?
Titaniums have better treble extension than the fibre/wool variant, but the diaphragm material is thick, heavy. So Yes, I would also expect it to have more low end. Also a tuning foam is goint to help on the back of the driver. But that dip at 7k-8k seems big. Lets see how it goes when You build it!
Aug 21, 2021 at 9:34 PM Post #3,894 of 4,718
Well fortunately I still had 1 extra red film driver from another pair which got damaged.
MMCX converted the K's LB shells and put my pair of 150Ω red film drivers in them.
If I hadn't had that one last red film driver, these would have gotten the 32Ω Ti drivers which also have very good sub-bass extension.
Aug 21, 2021 at 9:41 PM Post #3,895 of 4,718
I went around the outside rim and cut the glue free of the driver. Just bad luck some was between the face of the cover and on the diaphragm. Even if I had cut the side I would have had a problem. :weary:
Aug 22, 2021 at 5:43 AM Post #3,896 of 4,718
Does anyone have some tips on opening up glued mx500 shells for the purpose of recabling? The cable of my faaeal iris 2.0 frayed and snapped above the inline mic and I need to replace it but unlike other mx500 buds I have the faaeal cannot be easily opened I assume this is due to glue. (The other buds I have are vidos and a traceless, which I also plan on re-cabling because their cables have become stiff and I would use an inline mic).
Also is there a recommended newbs guide to recabling mx500 buds? I have done some rudimentary soldering, swapping dead capacitors but nothing advanced. Is there anything in particular to watch out for when soldering the replacement cable onto the drivers?
After reading through a bit of this topic I am also intrigued about putting a red dot 19-21 driver which many have recommended in an old broken
(coil snapped) vido shell. Will that shell have appropriate foam or should I order some separate tuning horseshoe foam for that driver?
Aug 22, 2021 at 6:35 AM Post #3,897 of 4,718
Try heating it, the glue may get more flexible.
Then this is my preferred tool. It can be found in kitchen drawers, bars and pubs:
This is how to use it on buds:
The firs tool is best for PK shells but it depends how it grabs the cover.
Aug 22, 2021 at 10:38 AM Post #3,898 of 4,718
:beerchug: :joy: This is great topic. Can you make some "analysis" (you know where :wink:)
Aug 22, 2021 at 12:08 PM Post #3,899 of 4,718
Hi there,
How's the red film on LB shells sound sig compared to pks?
Aug 22, 2021 at 3:52 PM Post #3,900 of 4,718
I don't like the Vido shell. I do not recommend putting any driver in it. I even tried 19 21 red dot. I mean the red shell, I don't know the rest.
