Some time ago, someone came up with the concept of "flat" cables which allegedly solved the problem of entanglement ie. "tangle-free" solution.
For me personally the main problem is the "springy" effect which is common with these cables and microphonics.
I had several such earbuds that I got with the phones or bought for testing.
The biggest complaint of all of them is very, very cheap plastic used for shells and not common driver size.
Even cover shape is so unique for most of these models. They did this to provide better comfort without the use of pads. Of course, this causes other problems like slipping, lack of bass, harsh treble, in one-word DISCOMFORT.
Your 1st model seams to use standard 15.4mm mesh-cover driver but the question is whether the shell holds the cover (has "lips") or is it just glued to shell body.
2nd model has is a familiar cover concept. Rubber ring holds a mesh grid in front of the driver. I had a similar model, the size below 14.8mm (13.5-13.8mm).
I couldn't use them for anything, even the cables they use have such thin wires, even thinner then MMCX short wires.
3rd model has a bump on the cover. I had trouble taking off this cover because of glue. The size is around 15mm or so, I can't remember.
Your model has an interesting "advanced" vent system from the back.
