Themilkman46290
Well, after a few days burning in the 64ohm ti for $15 I can say it's one of my top 3 favorite drivers, right under the 400ohm and 130ohm drivers
And I can definitely say, the 500ohm driver has a bit more sub bass then the 600ohm (nsc had told me it would have more bass) but to my surprise, the highs also are better, I would recommend them over the 600ohm
Also decided to experiment with some random shells, and I found an interesting but large option, after tuning, using the 32ohm n52 driver, I was able to get a very deep Soundstage, with deep rumbly sub bass, clean mids and clear, smooth highs
Used a puma shoelace, with cheap aipinchun 4 core 2mm cable from yuming, a bit of heat shrink with glue(for the y split) and two 16mm volume knobs for shells. Would be nice if the knobs had a taper but luckily the sit in my ears without falling out
