DIY Cable Questions and Comments Thread
Oct 24, 2020 at 1:25 PM Post #9,832 of 10,590
Does someone knows these plugs from CEMA Audio:
https://de.aliexpress.com/item/1000007901246.html?spm=a2g0s.8937460.0.0.15522e0ecrG9k9
Oct 25, 2020 at 7:00 PM Post #9,833 of 10,590
Hi,
I would like to make my first cable and I have a few newbie questions. :) I own 6.3mm TRS Viablue plug:
and two 3.5mm TRS plugs:
How do I solder it properly? AFAIK in 6.3mm plug Tip is for L channel, Ring is for R channel and Sleeve is for return signals. I am confused about mini jacks as they are 3-pole too. How do I connect them to big jack? Do I ignore one pole? Will such cable work with all headphones that accept 3.5mm jacks? I saw TS and TRS mini jacks in various headphones. Not sure what point of three poles in headphone plug is.
Oct 25, 2020 at 10:54 PM Post #9,834 of 10,590
Those who have made balanced cables using a sheilded quad cable. Assuming you remove the shield from the split up to the cups. Do you retain the shield from the split to the plug, and if so, so you solder it to the Ground lug on the XLR, or just cut it short and heatshrink it?
Oct 26, 2020 at 1:25 AM Post #9,835 of 10,590
Does anyone have any experience using damping material in a power cord? Such as using fine steel shot like was used in the old audio dynamics power 3 cord? Just curious if there was a cheap source somewhere.
Oct 29, 2020 at 10:24 AM Post #9,838 of 10,590
I have perhaps a very stupid question. I'm in the midst of building my very first IEM cable. Sourced 5 meters of UP-OCC 7N Copper from Aliexpress. I'm really liking these Eidolic 3.5 jacks, but I can only get balanced ones. Can I use balanced jacks as unbalanced? Will it change anything? I cannot seem to find a direct answer to this.
Edit: solved, was actually able to source a single ended black Eidolic 3.5 for 8euros.
I'm now looking for MMCX pins that would fit the design of the Eidolic plug, I found these which I really like, very simple, straight and geometric, but I'm a bit skeptic about the beryllium claim. Any pointers?
https://fr.aliexpress.com/item/4000809011764.html
Any MMCX pins with the same design I could get elsewhere?
Oct 30, 2020 at 12:48 PM Post #9,839 of 10,590
Here my pimped version of the Cardas Clear
Oct 30, 2020 at 1:53 PM Post #9,840 of 10,590
Here my favourite
Made from a B&W Signature Cable
