DIY Cable Questions and Comments Thread
Jan 15, 2017 at 8:58 PM Post #6,181 of 10,589
The LCD 2 diy cable is confusing me...
I have 4 cables. On my TRS I have 2 soldered to the tip and 2 to the ring. No ground, right? Left channel is one wire to 1 and the second to 4. Grounds (2&3) aren't touched. Same on the other side. Can anyone explain what I'm doing wrong? Not sure how im supposed to ground the cable with only 4 wires. Do immediately just solder 2 and 3 together? I don't want to ruin my cans. Thanks.
Jan 15, 2017 at 9:14 PM Post #6,182 of 10,589
You have 4 wires or conductors not cables and if you have 4 for a trs connection 1 wire to tip 1 wire to ring and the grounds go to sleeve. Left + tip Right + ring -''s go to sleeve.
Jan 16, 2017 at 9:44 AM Post #6,187 of 10,589
HifiMan HE-400i has 2.5mm TRS connector on headphone side. How do I connect them to 4 Pin XLR?
https://www.google.com/search?q=4+pin+xlr+pinout&rlz=1CDGOYI_enUS723US723&oq=4+pin+xlr+pin&aqs=chrome.3.69i57j69i60j69i61j0l3.19689j0j4&hl=en-US&sourceid=chrome-mobile&ie=UTF-8#imgrc=kWIBL7A5gMmhvM%3AThat is a female plug where you would need a male end.
Jan 16, 2017 at 11:22 AM Post #6,188 of 10,589
I am talking about 2.5mm TRRS/3.5mm TRS connector that connects to source. On headphone there are  2.5mm TRS connector for each left and right. That makes total 3+3 wire, how to connect these to 4 pins in XLR?
Jan 16, 2017 at 12:11 PM Post #6,189 of 10,589
There are only two wires on the 2.5mm trs connectors going to the cups. The tip is your positive for each side.
Jan 24, 2017 at 7:10 AM Post #6,192 of 10,589
Anyone tried this wire? http://www.ebay.com/itm/281831106775?_trksid=p2055119.m1438.l2649&var=580816709756&ssPageName=STRK%3AMEBIDX%3AIT or maybe this one http://www.ebay.com/itm/182187600450?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT or this one
http://www.ebay.com/itm/10m-Vanguard-0-2mm-square-high-purity-silver-plated-OCC-wire-Hi-Fi-Audio-cable-/132021890900?hash=item1ebd1e2f54:g:-DYAAOSw-0xYQbjH
Seems quite cheap and nice and i was looking for a nice looking one to recable my broken inears. I guess i should go for the 24awg size?
Jan 24, 2017 at 9:14 AM Post #6,193 of 10,589
That SPC in the first link is insanely cheap - I might have to give it a go and see....
Jan 24, 2017 at 11:28 AM Post #6,194 of 10,589
It's going to be pretty stiff for in ears I believe that is the 19 strand stuff I have very stiff.
