Hakase
The top connector is stereo, trs (tip ring sleeve), the bottom is mono TS (tip sleeve). I am not real familiar with those headphones but if you are planning on plugging the 3.5 mm into a device then it should be stereo like the top connector. The top connector also has an extended tip that helps if you are plugging into a smart phone or table that is in a case. That being said, I am not sure if the top connector has solder lugs inside, if not I prefer connectors like Amphenol:
That's exactly what I wanted to know, thanks
Could you link a good dealer for the Amphenol connector?
Be very careful with LunaShops. I've ordered from them before, and was never happy with the results. Their stuff is very cheap, and in one case, useless. The 3.5mm mono jacks I ordered had no threads to connect the plastic shell to the plug.
I think you want to know which plug to use on the end of the cable that doesn't plug into the headphones, right? Assuming you want a 3.5mm jack, you need a stereo one, which has the three connections (the pic on the top). There are many places to get a jack other than LunaShops. This one from Markertek is a good, basic quality jack, but might have issues if you are plugging into a phone with a case.
Okay, that's what I needed to know. I wasn't planning on getting anything from LunaShops it was just a quick picture I found off of google. Thank you for the link to Markertek
