95 1-Strand Paracord Type 1
https://www.amazon.com/gp/product/B00KXEL43A
Mogami W2799 stripped and inch-wormed into the paracord. I used plumbers tape (PTFE tape) around the end of the wire to feed it in. Make sure to cover about two to three inches of the wires with the tape before feeding it in.
All good advice, thanks. Plumbers tape is probably Teflon tape I would think, I just bought some for a bathroom remodel in my home. I have several sizes of paracord on the way including micro, 275, and number 1. I would think braiding helps with microphonics, the cable I got with some MrSpeakers exhibits none. A straight run probably allows vibrations to travel consistently right down the jacket. That and jacket tautness is more likely to occur and transfer sound just like a string between tin cans. The cable I got with the aforementioned cans had the same color code as the 2799 so there are quite a few people using it I would think. MrSpeakers advertises Canare in their standard cables and that is another good brand I am sure. Belden has it as well but if a person could buy good quality 24 or 26 awg. ofc or HP ofc I am more apt to go that route. I will find something yet.
heh heh, I used to call it that too. From Wikipedia:
It is also known by the genericised trade-name Teflon tape; while Teflon is in fact identical to PTFE, Chemours (the trade-mark holders) consider this usage incorrect, especially as they no longer manufacture Teflon in tape form.
