- Aug 14, 2014
Hey guys, I've been reading in the DIY cable thread and this one, but I haven't really found any tutorials on how to make one from scratch. I have a MEE audio Pinnacle P1 and I really do not like the cables it came with.
Can I just buy a 3.5mm jack, some wire, a Y-splitter, and the MMCX connectors? Is it that easy? Or is it that easy on paper? Or is it not that easy?
Thanks.
Yeap basically that's the materials. Make sure you have 1 wire for each connection. So at least 4.
Tools
Soldering iron around 350 degrees Celsius is what I use.
Solder, just about any one will do unless you're willing to cash out more for wbt or mundorf solders.
Heat shrink
Hot glue
A third hand tool. The one with 2 hands and a magnifying glass. If possible get the one with a sponge grip.
Wire strippers, there are 2 kinds, the automatic one where you don't have to actually pull the insulation out. Only thing is your braiding will have to be unravelled. Or the standard clipper kind but when you pull on the wire it may be pulled tighter on the braid and will extend.
Clippers and needle nose pliers
Multimeter
Check out my Instagram page @radynamics the first few pics are how my soldering is and how I insulate. I'm working on a tutorial soon.
So from bottom up.
It's get wires. I cut them to 1.5m before braiding.
I braid before doing any soldering. However some guys solder the wires to the jack first. 4 wires so 2 to ground and 1 to each live.
Then they will press that onto a large piece of blu tack to anchor and then braid.
Make sure you insulate and slide on the jack barrel and any heat shrink you need for the y split and cable cinch.
Then before splitting use the multimeter to test which cables are ground and which are live. You want to split them such that each side will have 1 live and 1 ground
Twist the 2 wires as a braid first, doesn't have to be so tight. Slide on the MMCX barrel and any heat shrink for ear guide before soldering. Solder and then I use a some hot glue around the connection and slide a heat shrink over. Then slide or screw on the barrel. After that I recommend using a small pick to stuff hot glue into the barrel opening. Make sure the opening is filled. This is to reduce the pull on the solder points.
I strongly suggest using eidolic MMCX connectors. They are the most well made and have slightly larger soldering points. Their barrel is also wide enough such that small imperfections is okay. It's well worth the money considering how I burned through 3 **** connectors making just 1 cable.
Hope this helps and all the best! It's a challenge but a very rewarding one
