- Jan 21, 2013
It'll depend on the connectors we end up using. Since he wants two straight mini to mini connectors, it allows me more breathing room at the transition point. I have adhesive heatshrink that is very easy to work with and would offer a good result. I'll likely try and find tubing with a diameter that fits into the tubing so I can heatshrink it to the actual connector inside as well as outside.
One Head-fier asked if I could make him an interconnect. We talked about the style he wants. While I've never done one in the style he's asking, I'm always down to try and find a solution. Think I'm going to check out some vinyl tubing. Hit up Home Depot and maybe the pet store aquarium section for different tubing options.
My only real concern is flexibility. I just thought I'd ask here first. Maybe someone could save me the few hours of searching, trial and error.
You might find some clear tubing at an auto parts store. They should have some various diameters of tubing that is clear. Some of the tubing might be a bit thick but you'll have to see what is available at the store. Also, consider how you'll transition from the tubing to the connectors - shrink tube?
