DIY Cable Questions and Comments Thread
May 29, 2014 at 2:26 PM Post #2,041 of 10,590
I got my Mogami W2799 for $0.64/foot from Redco.  Best price I found at the time (about 4-5 weeks ago).  That's $0.16/foot per wire, and it sounds great with my cans.  I didn't braid them, just used 550 paracord; light and supple.
Can that be used for iem? I also bought 5ft from redco.
By the way, do you buy nylon or polyester paracord?
May 29, 2014 at 2:36 PM Post #2,042 of 10,590
Dunno, don't have IEMs.  The Mogami site has all the measurements.
I used this:  http://www.amazon.com/dp/B007Y8YJ62
but not that color
May 29, 2014 at 5:36 PM Post #2,043 of 10,590
  Hey why don't you get Mogami microphone cable ? it's about $0.80 per ft and it has 4 separate cables. making iem cables will cost you less than $4.
You can tear off the outer teflon and use the small paracord sleeve.
I might do that, bought the smaller mogami and paracord already.
I bought plussound 28 AWG 7N Pure UP-OCC Stranded Copper Custom Wire. not going to put paracord on it this time may on the next cable. also have a Viabule spliter on the way..
May 29, 2014 at 5:49 PM Post #2,044 of 10,590
I bought plussound [COLOR=666666]28 AWG 7N Pure UP-OCC Stranded Copper Custom Wire. not going to put [/COLOR]paracord on it this time may on the next cable. also have a Viabule spliter on the way..
That is a nice cable!! Let me know how it turns out.
May 29, 2014 at 11:43 PM Post #2,045 of 10,590
Do you guys know where to find—for lack of a better description—a larger diameter paracord? I'd like to sleeve a cable that's almost .25" in diameter, and for this application, I'd really like to have fabric rather than techflex.
May 30, 2014 at 1:37 AM Post #2,048 of 10,590
Techflex Nylon Multifilament, e-Bay is one to go to. Markertek sells ONLY 1/4" ID sleeve. Redco sells shop rolls of most sizes, however it's a non-stock item so double delivery time for the order.
May 30, 2014 at 5:14 AM Post #2,050 of 10,590
If you want I have some black 1/4 that I can sell you cheaply. I bought 100 feet and there's no way I'm going to need that much as the projects that are thick enough to use it on are very rare. PM me if you're interested.
Jun 2, 2014 at 5:13 PM Post #2,052 of 10,590
When making an iem cable, should I use 2 ground wires or bridge at the y split?
you need two ground and usually both are soldered to the ground on the connector but I guess you can do it at the Y split if you want, but if you ever want to go balanced you are going to need a whole new cable, instead of just a connector.
Jun 2, 2014 at 5:14 PM Post #2,053 of 10,590
This depends on the wire and whatnot. With 28awg, the wire is thin enough to braid both grounds in separately and if you don't braid things too tightly it comes out really flexible. I've bridged them at the split before, and it's not bad, but then you have a point of failure. I usually wrap the bridged area in a bit of electrical tape and then heat shrink over that, only covering a tad more than I need to of the soldered wires. Depending on the wires, it's easier to roll up a wire for storage when there is no bridge like this in the middle of the cable...
Jun 3, 2014 at 4:16 PM Post #2,054 of 10,590
awesome reply, I've looked at connectors and have gotten mixed results.what would you recommend for durability?
Jun 3, 2014 at 10:24 PM Post #2,055 of 10,590
Personally, i like neutrik, because they're reliable and affordable. If you want a step up in looks while still being very durable, viablue makes nice connectors. Most of the popular connectors on these threads are pretty durable though. I find it comes down to size, appearance and design, whether for soldering or fitting a certain application...
