kelly
Herr Babelfish der Übersetzer, he wore a whipped-cream-covered tutu for this title.
- Jan 1, 2002
Phreon
Typically, I agree with this--your money goes further toward improving the sound with components than it does with cables in general. Or, another way to say it might be: Cables are like on tiny part of a component.
However: cables can definitely represent a bottleneck in high end systems and they definitely can make an audible difference. I have what I consider to be pretty well built power cables--twisted pair design, shielded, hospital grade connectors and yet, I've heard cables that sounded better in my system from JPS Labs.
There are a dozen theories for why power cables matter. The one I like the most is the one suggesting that the power supplies from the components generate noise that enters the power cable outside the component. Power supplies that emit less interference woudl therefore force cables into greater irrelevance. This may be one reason why some CD players and amps benefit more from cables than others (and if you search AA you'll find correlations and judging by how much they argue I don't think we can chalk it up to peer pressure). Of course, you can't tell by the brand of the unit, it's on a model by model basis which could support the idea that it's specific to the transformer used. Again, just one theory. There are others.
Similar to this is the theory with digital cables. Digital cables shouldn't matter. Those of us with any logical function left in our brains want to believe that no difference would be gained from switching digital cables. Once again, I've heard the difference myself. It's there. It's somewhat alarming, actually, because it's so obvious between some cables that it's impossible to dismiss out of hand. The theory here is that the DAC isn't doing a proper job of filtering and reclocking so the jitter is being passed in. Again, this would offer an explanation for why digital cables matter more on some DACs than others (and on transports).
Sorry--the point is that cables do matter and that things aren't as simple as they appear. But *in general* I agree, worry about your components first and foremost.
