kukrisna
- Jun 10, 2005
Hey All,
After revisiting DACs and all things digital I came to an assumption that I might not be feeding my DAC correctly.
PREMISE:
A) Source = MacBook Pro
B) two options for digital out:
1) built-in optical out
2) M-Audio Transit
C) two operation systems:
1) Mac OSX where i primarily use Cog
2) WinXP where i primarily use Winamp
D) IC = regular Toslink cable
E) DAC = Presonus Central Station
QUESTIONS:
A) is the built-in optical out bitperfect for all applications in OSX?
B) what's this about the CoreAudio MIDI settings in the Audio MIDI Setup in OSX? i have everything set at 44.1kHz and 16-bit anyway - should it be any different?
C) what's this about the M-Audio USB Audiophile sounding better than the M-Audio Transit even if it's just transporting the same digital signal?
D) what's this about hum and noise unrelated to jitter with the M-Audio Transit?
E) is there an advantage to either the M-Audio Transit or the built-in optical out over the other?
F) in WinXP, i have bitperfect out via Winamp and the proper ASIO configuration to the M-Audio Transit - if i use the built-in optical out, am i correct in believing that i have to tweak things again and that kmixer will be re-enabled and i will have to fix it again to achieve bitperfect out?
PERSONAL STATEMENT:
basically after reading back up on digital signals i became confused again:
- i am unsure if i do have a bitperfect signal on OSX via Cog and the M-Audio Transit - Cog does futz with volume and there's no indication of what the 100% is - if i max out the volume there is a lot of clipping so i think the default is correct though it sounds different than the "correct" sound settings in iTunes 7.5
- i am unsure if the built-in optical out would be better than the M-Audio Transit or vice versa
- i am unsure if the M-Audio Transit does its job well
- i am unsure if in WinXP, if i got rid of the M-Audio Transit, i would have to reconfigure Winamp and re-bypass kmixer if i started using the built-in optical out
REQUEST:
if anyone who really knows about all these things could help to clarify some of my confusion i will be most appreciative
thanks so much!
-keith
PREMISE:
2) M-Audio Transit
QUESTIONS:
PERSONAL STATEMENT:
REQUEST:
thanks so much!
-keith
