nick_charles
- Feb 26, 2008
We will have to differ on this one, I find it much more effectve than long term listening especialy if the differences are small.
It is rash to say "No one" since there may always be one undiscovered individual out there with greater discrimination talents , best you could say the odds against it lengthen and once you have several 1000s with the same result you start taking its pragmatically as read and stop testing for it so keenly. Since audio is less critical than say drug testing (where you really do have to be extreme) this is rational.
As for 2 and 3 perhaps but that is not informative or predictive and then requires you to devise alternative and suitably rigorous protocols, it does not let you fall back to "my wife was in the kitchen and she heard the dfference"
Maybe, but what "real" evidence for this do you have, you are speculating a lot here
I would venture that is why we have so much faulty evidence on the effect of cables, the assessment is done in a wholly uncontrolled manner where bias an expectation simply cannot be removed.
When Wlson did listening tests on some speakers they got one sample of listeners to be able to see the speakers and the others could not, without fail the sighted listeners always gave the speakers (visually impressive and expensive looking) higher ratings , it is just a human thing, similarly a big blingy(sp) cable compared to a stock cable....
I listen to sound only to see if I can tell a difference, normally I listen to music, but if I listen to music when trying to tell the difference between sounds I cannot tell samples apart so easily because my concentration is focussing on different things.
That said one could run a set of experiments where you have varying levels of difference between stimuli and you have different groups assigned and required to use one strategy or another.
Originally Posted by mike1127 /img/forum/go_quote.gif I'll back-pedal a little and say that even though a test cannot directly control the use of the attention, it certainly can influence it. For example, a quick-switching protocol, or one that uses segments like you describe, has a very strong influence on how someone uses their attention. See my post earlier in this thread for my explanation why this can block access to information. |
If 100 subjects (who are all using their attention in their own way) can't detect something, it could mean:
Remember that some people spend much more time introspecting on how they use their attention. Being a musician and constantly working with small differences in sound could influence this. So could being an instrument-builder. Someone who practices mindfulness meditation would be influenced. |
It comes down to this: most audiophiles get the impression of differences between something controversial (like cables) in either initial impressions, or long-term living-with-the-component. Very, very few DBTs replicate these conditions. |
EDIT: you are clearly listening to sound. I listen for music. That right there is a huge difference in how we use our attention. |
