No. It is simply a myth that different solid state amps change the signature of a headphone as long as they all measure flat and have low impedance. So no, different amps don't influence the FR of a headphone if they are uncolored like most solid state amps are. At best I could see different filters being implemented for the high frequencies that would roll off the highs earlier than normal but even that wouldn't significantly impact the FR.I have zero knowledge in analyzing/interpreting FR graphs, but I do have a question that may sound stupid:
If I listen to a headphone with two different amps, and those two amps give different sound signatures to the headphone (let’s say one gives more presence to the bass and the other one focuses more on the midrange), would that result in two different FR graphs after it was measured?
I think the issue with this whole controversy is that people don't necessarily listen to headphones the same way. Some people are WAY more picky about FR than others (myself included). Any odd peak or dip can ruin a headphone for someone is a perfectionist and wants the most amount of clarity and no harshness. I would say that was the primary reason why I sold most of the headphones that I've owned over the years.
I think the THD measurements in particular look a bit too flattering but I don't think that this was intentional in the sense that your other measurements also present that way. I seem to recall a THD measurement of the HD6XX which showed a lot less THD in the bass than other third party measurements. I'm guessing some kind of weighting is used because in my experience I could kinda hear some distortion in the sub bass on that line of headphones.While I'd see no problem with them asking me to measure it (even in this context) they did not in this case. Companies from all over ask us to measure prototypes and products regularly, so it's something we're used to here. The activity has stepped a bit lately, as there's a growing interest in seeing 5128 measurements from some who are thinking of picking one up.
