Seidhepriest
- Aug 16, 2007
You know, the recable+cotton ring fix bass definition problems. AH-P372 clamp, they don't vibrate much until Really Loud.
As a little warning, blocking the foam underneath the diaphragms will make them sound much flatter. The cotton ring just kills the boominess, but blocking the diaphragms' backwave will remove the "3D" part of the sound. Also don't lay any cotton or acoustic fibre over the reflector plate. The reflector plate and backwave are part of the "Foster sound".
You could try coating the reflector plate with paper or thin felt - that'd remove whichever plasticky echoes there still are (the foam under diaphragms should already filter most of the high and low frequencies). Or, you could try removing the reflectors altogether, and stuffing the cups with acoustic fibre.
