Corti
Thank you for your reply and instructions.Hi,
The lacquer is really tough, so paint stripper is needed. I first tried a finish remover that cuts through wax, french polish, light lacquer to no avail, I wanted to use the least 'aggressive' method possible. I dismantled the headphones to do this, there is no other option. You will need a torx screwdriver or bits to dismantle the cans.
I had to use two coats of paint stripper, and even that didn't remove all the lacquer, I also used the less aggressive finish remover and steel wool with a lot of 'elbow grease' to complete the task.
When the wood dried out I rubbed it down with very fine glass paper then a final rub down with steel wool before applying the wax.
Over the past couple of weeks I did ponder over reattaching the 'DENON' letters, but ultimately I prefer to see as much walnut as possible, so the letters will remain stored away.
An oil finish would also be fine, either linseed oil or walnut oil would suffice. If you want less mess and want to avoid the drying time between coats of oil drying, then take the route I did and settle for wax.
What wax should you use if you opt for a wax finish? Some exotic expensive furniture wax possibly?
Well you could if you have money to burn, or you could take a tip passed on to me by a late master gun stock maker with over half a century of experience........
Buy a tin of neutral shoe polish! It's got everything you need in it at a fraction of the price of 'snake oil' wax!
that sounds like a good amount of work.
but if i have learned one thing while working with wood or handcrafting in general, it's that
every minute of effort was totally worth it, when the outcome is satisfying.
I'm just hesitant because i bought a quasi new unit (open-box), and if making
a major modification i should be very certain to be keeping that headphone.
and after dismantling i think the warranty is pretty much gone as well.
Then again the build feels really sturdy and probably nothing's gonna fail (i mean the price
has to be justified by something..).
those derps over at denon should have just used a wax or oil finish and a bit more headband-padding.
maybe they tested the headband on some zen-monks, those that destroy stoneplates with their heads
