How does It sound?
Would you please do a brief review and comparison with your previous devices
So as I said I would after getting back to my permanent residence, I’ve just plugged in my Pontus II into my home system. The system includes tubed pre and power amps and full range planars, silver cables throughout.
For now, I used the NOS and polarity +.
After a full warm up in the system for at least 7 hours, I’ll say my review is mixed. Weight and scale of size is definitely more noticeable over the less priced Ares II, as it should be. The Pontus has a much better power supply addressing each the digital and the analog sections, so no surprise on my above observation. Music seemed to come from all around my speakers with a much better midrange presence and low end. At this point I was extremely happy with what I was hearing and my choice of the Pontus over the Ares for my home system. As a side note, and as they say YMMV, the Ares II is all I would go with for a headphone system. It is very good at that position, where as the Pontus I believe would be overkill and under utilized in that spot for music presentation. In a large room with full range speakers, Pontus or “god save me“,even higher up the Denafrips line up would be my suggestion. I did swap both the Pontus and the Ares into my Stax 700/007tll system and felt the law of diminishing returns became obvious very quickly. Thus unless your cash sources are unlimited for an audio budget, the Ares is that good and no need to spend more to run a good headphone system. At home, go bigger and be amazed!
Now, what wasn’t so good but I will stress with only 7 hours, and I’m sure when I hit 100 or more hours, based on my experience with break in, it will settle down. I will report back if I do not hear any improvement. So on to it. Upper frequency seems truncated along with soundstage confusion is the best way I can describe it. A little bit of fuzziness around instrument. Placement seemed ok but could have been more precise? As a side note my system is run single ended vs balanced as my preamp doesn’t have bal inputs.
So, I now have my CD transport running my PAD breakin CD as directed, and will then run in for a week with music.
Back in a week with an update on the Pontus. But for now I will say unequivocally how good the Ares II is for the money. Based on my current experience, might be the only dac one needs in a modest hi-end system
