Yes it is true, I'm also using an iPower X to power the X-SPDIF 2 ... So there is another free plug for ya, lolThis would imply noise reduction, which is always good
Denafrips 'Pontus' R2R ladder DAC - close up view
- Thread starter PitBul34
Myshkin
- Oct 26, 2016
I've been using my pontus through optical because I cannot seem to get the usb drivers to work, at first I thought it was just my particular PC but I can't seem to get them to work on my laptop either. I install them from the site and find the dac in device manager and select the newly installed drivers but it gives me a failure to start error. Does anyone have experience with this issue? I'll also give emailing denafrips a try.
jwilliamhurst
Definitely email Alvin at vinshineI've been using my pontus through optical because I cannot seem to get the usb drivers to work, at first I thought it was just my particular PC but I can't seem to get them to work on my laptop either. I install them from the site and find the dac in device manager and select the newly installed drivers but it gives me a failure to start error. Does anyone have experience with this issue? I'll also give emailing denafrips a try.
Myshkin
- Oct 26, 2016
Gave him an email and sorted it out, USB is now working!Definitely email Alvin at vinshine
Edit: I don't know if it's burn in or what but USB is sounding a lot better than optical was, I'm even more amazed!
FooFighter
That's an interesting point as I made the same experience with Streamer Bluesound Node N130 and thought it's the Streamer, tried Coax and Optical, unfortunately the Streamer doesn't support USB out but from my iPhone / IPad / Shanling M8 DAP / Macbook Pro via USB the sound signature was clearer, more lush and mature in contrast to a tad too bright with emphasized upper mids through Optical / Coax...Gave him an email and sorted it out, USB is now working!
FooFighter
Anyone using a (passive) switchable XLR splitter/hub yet after we learnt that only one output is allowed at the same time?
My scenario
1. DAC at desk to local amp at desk
2. DAC at desk to remote amp at sleeping couch
Example from German Amazon offer
Nobsound 1-IN-3-OUT XLR Audio Switch ; Balanced Audio Converter ; 3-Way Stereo Passive Audio Selector Switcher (MC103 Pro 3-Out) https://amazon.de/dp/B07R51XN2Q
My scenario
I have a couple of those exact units. Works pretty well for the money. I've noticed no issues with cross-talk between inputs etc., and its pretty convenient for just as you are describing, 1 DAC to multiple amps. Most recently on my secondary setup, Bifrost 2 xlr out into a One Little bear and then xlr out into a Jot 2 and the other xlr out into a Liquid Platinum. Not using any fancy cables either, just Worlds Best XLRs with Canare L-4E6S wire.Anyone using a (passive) switchable XLR splitter/hub yet after we learnt that only one output is allowed at the same time?
What was the problem??Gave him an email and sorted it out, USB is now working!
Myshkin
- Oct 26, 2016
I'm not sure it was as simple as unplugging the dac's power for 10 seconds and plugging it back in. I really should have thought of that myself!What was the problem??
alvin1118
Member of the Trade: VinShineAudio
- Jun 13, 2008
I should chime in to clarify.
@Myshkin shared the screenshots of the winOS Device Manager with me, it appears that the DAC was in ‘Firmware Update' mode. It could be accidentally triggered by a set of buttons-push-combination.
To exit/cancel the 'Firmware Update' mode, simply power cycle the DAC.
Hope this helps
jwilliamhurst
How does the Pontus sound with the flux labs fa-10? I’ve been looking at the fa-12 myselfI'm not sure it was as simple as unplugging the dac's power for 10 seconds and plugging it back in. I really should have thought of that myself!
Myshkin
- Oct 26, 2016
It sounds absolutely wonderful, everything is very spacious, detailed, and natural sounding. I am blown away by this combo every day I use it, it seems to be getting better each day with the dac burn in. I should note my fa-10 is modded with replaced caps that gives it more spaciousness and detail than stock.How does the Pontus sound with the flux labs fa-10? I’ve been looking at the fa-12 myself
Compared to the JDS labs dac I was using earlier this pairing seems like such a great match. The fa-10 and pontus compliment each other very well in my opinion.
- Mar 20, 2013
and and
Stay updated on iFi audio at their sponsor profile on Head-Fi.
Myshkin
- Oct 26, 2016
I had quite a scare this morning! I went to listen to my setup with my coffee and notice a ton of popping noises while audio played. I thought maybe some equipment had gone faulty but luckily after restarting the USB driver for denafrips everything was back to normal Posting this in case this ever happens to anyone else.
FooFighter
Thank God I am on MacOSI had quite a scare this morning! I went to listen to my setup with my coffee and notice a ton of popping noises while audio played. I thought maybe some equipment had gone faulty but luckily after restarting the USB driver for denafrips everything was back to normal Posting this in case this ever happens to anyone else.
Total: 6 (members: 0, guests: 6)
