sajunky
Enjoy your Ares!Update: Well, I can not be sure if I have that bias thing, but I think connecting it to the keyboard (usb 2.0 inside) and keyboard to macbook, sounds less shouty the female vocals high. When using the usb 3.0 hub, I would swear it's less transparent sound, and the female vocals high sound more glary, more piercing.
Used pj harvey song, to talk to you, 24-96, audirvana. upsampled x2.![]()
![Headphone Smile :) :)](https://cdn.head-fi.org/e/headfi/smily_headphones1.gif)
Yip, it is reported by many that USB 2.0 phy is less noisy.
Your journey only begins. I have to add, that keyboard is USB powered. Better result are when using USB 2.0 hub with external power supply. And then you can experiment whether it is better to plug it to a keyboard port or directly to a laptop (in my experience better, but make your own tests). Keyboard can be plugged to this hub, but no more devices, just DAC and optionally keyboard.
External power supply is important, as it redirects ground loops to a hub's power supply. It is what ifi defender does. It can be a quality LPS for better results, but you can try a typical USB charger first.
