AlanU
- Apr 20, 2015
Simon,Thanks. Finally something about Ares II in this thread, not just read about DDC...
regards,
Simon
I was fortunate enough to have a friend steer me the right way in serious sonic improvements.
Let's just say you purchased a re-clocking DDC. This external device can be a stop gap as you move up the chain in denafrips or any other brand DAC.
What you really need to do is explore and listen with your personal ears. My hunch is majority of the people out there will careless about 32 bit or MQA nonsense after serious source treatment.
If you think your ARES 2 sounds good. You have NO IDEA what you are missing if you feed it a reclocked signal. I always assumed that my setup was fantastic. Now that I've purchased 1 re-clocking DDC, I'm now considering purchasing an external word Master clock. Howerver i must first pruchase my second DDC unit to daisy chain. Mind you the Mutec costs more than the Denafrips ares alone. However if you approach music and be serious about the importance of SOURCE, any dac you purchase will have the higher level data stream. Higher quality signal with precision timing will be the input to the dac. This is where the translation becomes much easier for the dac to translate the original intended recordings from the artist!!! Jitter effects the timing and the D to A conversion uses the time sequence during conversion. Skewed square wave will be translated as Skewed sine wave. This is why reclocked precision feed will have darker backgrounds, more layers, texture, detail, analog ease, instrument separation and digital glare disappears. If a VENUS ii does a good job in input treatment, a re-clocked well spec'd DDC will improve it further. Not fiction......... fact!
Please note, to a degree your DAC is not truly the source. The music "SOURCE" stems from the internet going into your house and the media server/streamer that feeds "DIGITAL" information to your DIGITAL TO ANALOG converter.
IF you have considered an audiograde ethernet switch and re-clocking DDC you are serious about analog ease and true audio performance. Simply purchasing a DAC is IMO wishful thinking as Garbage in = Garbage out. Purchasing an ARES and fed with a re-clocking DDC will sound better than a stand alone Jitter infested digital signal to a higher line PONTUS. Please do not take my words as fact. I've done plenty of tests and found that jitter = digital glare. Remove jitter and you will have a cheap and cheerful dac turn into a more serious stellar performer.
Amongst my friends I've suggested looking into a DDC before buying a new DAC. All of them are floored with their EXISTING dac and NO change to their audio components. I made them aware to be more serious about source. Source is EVERYTHING! If you achieve "endgame" source quality, concentrate on upgraditis first world problems of buying "better" upgrades DOWNSTREAM.
Visualize a herd of elk foraging and dwelling 1/4 mile in a creek/stream. You are downstream from the elk. Will you drink the water or treat it before you do so? LOL!! The water is your source to replenish hydration.......
Using a boutique $$$$ passive usb cable does not resolve contamination where it happens up stream. An active device intended to preserve the 1's and 0's with precise timing as intended by the artist is the goal.
If you cannot see my point, DDC is a waste of time
