npcraig
- Feb 18, 2009
So does this do FLAC?
Originally Posted by npcraig /img/forum/go_quote.gif So does this do FLAC? |
Originally Posted by woof07 /img/forum/go_quote.gif The most current firmware revision does. That's all I have on mine. |
Originally Posted by npcraig /img/forum/go_quote.gif Nevermind, I went and downloaded V02.01.32A and FLAC works now |
Originally Posted by woof07 /img/forum/go_quote.gif Isn't it awesome? No software, no media tie-in needed...just drag over files (I am assuming it uses a Band folder, Album folder, song files structure 'cause that's what I did) and you're good to go. For $50, wow. |
Originally Posted by mail4u /img/forum/go_quote.gif I have one problem with the clip: in order for my computer to recognize the player I need to first put it in "hold mode" and then press the center button while connecting to the computer. Shouldn't it just connect without having to do these procedures? Anyone else having to do this? |
Originally Posted by bixby /img/forum/go_quote.gif Try going to Settings>USB Mode> and check MSC then exit out and hook up to your computer. |
Originally Posted by bixby /img/forum/go_quote.gif Try going to Settings>USB Mode> and check MSC then exit out and hook up to your computer. That worked for me running XP and after connecting to the USB cable the little pop-up window came up asking if I wanted to open with Windows Explorer. For some reason the default was auto detect but that did not work. Let us know what happens. FYI My Walmart is sold out for a week now. |
