dCS Ring DAC - A Technical Explanation
Apr 22, 2021 at 4:19 AM Thread Starter Post #1 of 187
Cambridgeshire, UK
Hi folks,
James here from dCS.
We have been working on a series of posts for Head-Fi.org that cover the basics of topics like digital to analogue converters, clocking and filters. The aim of these posts is to help people gain a better understanding of digital audio products, so they can make more informed choices when it comes to their equipment. These posts will of course have a focus on dCS equipment and our approach, but we will be aiming to discuss technologies and engineering approaches, not brands or specific products. As such, we hope the information is useful whether you are an existing or prospective dCS customer, or just a digital audio enthusiast looking to learn a little more about the topic.
The first area we want to cover is the Ring DAC. It is one of our key technologies and found in our products, and is unique to dCS. I’ll be explaining a little around the basics of digital audio as well as the common DAC types along the way.
Part 1: Basics of Pulse Code Modulation (PCM)
Part 2: Basics of Pulse Density Modulation (DSD)
Part 3: Introduction to D/A Conversion
Part 4: The Ring DAC
Part 5: Filtering in Digital Audio
Part 6: Filter Design in ADCs and DACs
Clocking Posts
Part 1: The Basics of Clocking
Part 2: Jitter (Intrinsic)
Part 3: Jitter (Interface)
Part 4: Clock Synchronisation
Part 5: Asynchronous Sources – USB & Network Audio
dCS Stay updated on dCS at their sponsor profile on Head-Fi.
https://www.facebook.com/dCSonlythemusic/ https://twitter.com/dcsonlythemusic/ https://www.instagram.com/dcsonlythemusic/ https://www.dcsaudio.com https://www.youtube.com/channel/UCQf2YCUG5UfXwZapkuTwxLw info@dcsaudio.com
Apr 22, 2021 at 4:21 AM Post #2 of 187
Part 1 – Basics of Pulse Code Modulation (PCM)​
To me, when explaining the Ring DAC – or DACs in general – it makes sense to start with the basics of digital audio from the perspective of PCM (all subjective debates on quality aside, I think anyone versed on the topic can agree it is the most prevalent format). For those already in the know, don’t worry, I’ll be getting on to the fun stuff soon!
Sound is analogue, and it’s created when varying amounts of pressure cause air particles to vibrate and bump into one another – a process that produces longitudinal waves. This is much like what would happen if you asked two people to stretch out a slinky between them and had one person push the slinky forward. Their push would cause a ‘ripple’ to pass through the slinky, pushing each coil forward and compressing it into the next. Each time a new coil is pushed forward, the previous one would retract back – or ‘rarefy’ – and this wave of compression would move through the slinky until it reached the other end.
This same process happens with sound. When a person speaks, their vocal cords excite and push the air surrounding them back and forth, and this creates longitudinal waves in the air. When these longitudinal waves reach an endpoint – the human ear – the changes in air pressure are translated into electrical signals that the brain perceives as sound.
The whole purpose of recorded music is to take these variations in air pressure and store them in such a way that they can later be reproduced by a transducer such as headphones, to enable a listener to hear the original audio event as it happened.
In today’s world, the most common way this takes place is to capture a musical performance with one or more microphones (which convert the kinetic energy in the particles of the air to electrical energy, a voltage) and use an Analogue to Digital Converter (ADC) to convert this into a format that can be stored by computers, streamed over the internet and so forth.
An ADC looks at the voltage that is coming in from the studio equipment like a microphone or mixing desk and determines how high the voltage is, storing it as a group of binary digits (1s and 0s), called a ‘word’. There are two key variables in PCM digital audio: The sample rate (how frequently samples are taken) and the bit depth (how many bits – 1s and 0s – are in each audio sample word).
This diagram shows how an analogue sound wave can be represented with 16-bit 44,100 samples per second PCM encoding.
Bit Depth
A lot of digital audio, including CDs, use a bit depth of 16 bits. This bit depth means that the ADC can have one of 65535 possible values at any given point. Bit depth refers to how many bits can be used to describe the absolute position of a sound wave in digital audio recording. It is generally accepted that the human ear can perceive equivalent to 20-bits of dynamic range, which equates to around 140dB (the upper limit being the threshold of pain). CD audio, in its 16-bit format, will achieve around 96dB of dynamic range (the difference between the loudest and quietest volumes that can be sampled). Through the use of dither, the addition of low-level noise to the signal, this dynamic range can be increased beyond 120dB, a significant improvement. Moving to a hi-res format like 24-bit, this dynamic range increases to 144dB – assuming the equipment is actually capable of working in true 24-bit.
It is a common misconception that 24-bit audio simply records louder and quieter sounds than is possible with 16-bit audio, but this is not the case. Instead, the same range of loudest to quietest is measured, but with 24-bit sampling it is done with considerably more steps than with 16-bit. This means the absolute value of the waveform at any given point can be much better represented.
Imagine for a moment trying to measure the height of a particular window on a skyscraper. In one case, you can only measure in increments of 1 metre. If the window is 10.7m high, you could round down to 10m or up to 11m, but in either case there would be a degree of error.
Now imagine the same situation, but this time you are able to use increments of 0.2m. The window is again 10.7m high. You are still unable to measure the exact height of the window, but being able to round to 10.6m or 10.8m brings you much closer to the actual value.
This is in essence what happens when increasing the bit depth of digital audio. You are able to measure the absolute value of the waveform with much greater precision, which has the effect of reducing what is known as quantisation noise in the audio. Quantisation noise is the audible noise which is generated by the error in the measurement. Essentially what this means is that when you measure the 10.7m high window as 11m, that 0.3m error in the measurement creates negative audible effects in audio.
When working with hi-res audio, each additional bit which is added to the bit-depth of a signal halves the quantisation error, quarters the error power, and thus reduces quantisation noise by 6dB.
Sample Rates
If the human ear can only hear up to 20,000Hz, is there any reason to use sample rates higher than 20,000Hz? As it happens, yes. One of the most important aspects of digital audio is the Nyquist Theorem, which specifies that the digital audio samples need to be taken at a minimum of twice the highest frequency one is trying to record in the original analogue audio. As the upper limit of human hearing is widely accepted as 20,000Hz, digital audio needs to be sampled at at least 40,000Hz to be able to reproduce the full range of human hearing. For reasons that will be discussed later (related to the digital filtering inside a Digital to Analogue Converter), full range recordings are sampled slightly higher than this, with CD audio being sampled at 44,100Hz. The rate at which these samples is taken is referred to as the sample rate, defining how many samples are used per second.
Further to this, running digital audio at higher rates allows for gentler anti-aliasing filters to be used (don’t worry, this will all be covered in future posts – these filters are incredibly important and warrant their own full explanation). In essence, higher sample rates and gentler filtering mean that the filters will be affecting the audio less, with fewer effects like pre- and post-ringing impacting the sound quality.
These two numbers, the sample rate and the bit depth, are what define PCM audio. The display of a dCS product playing back PCM data will show 24/192 when playing back a PCM stream with 192kHz 24-bit data.
This diagram shows how an analogue sound wave can be represented with 24-bit 176,400 samples per second PCM encoding. The sample rate being higher than CD audio above allows for a greater representation across the X axis of this graph, whereas the higher bit-depth allows for the exact amplitude of the wave to be more accurately represented with each sample – the Y axis.
Now we’ve covered the basics of PCM, we’ll move on to another widely used format, Pulse Density Modulation (the basis of DSD), before moving on to digital to analogue conversion.
Apr 23, 2021 at 11:08 AM Post #3 of 187
Bit Depth
Sample Rates
Now we’ve covered the basics of PCM, we’ll move on to another widely used format, Pulse Density Modulation (the basis of DSD), before moving on to digital to analogue conversion. That will be coming shortly in post 2.
Very interesting info. Thanks for the post!
Apr 23, 2021 at 11:30 AM Post #4 of 187
Bit Depth
Sample Rates
Interesting reading! I was wondering what's the cause/mechanics of the PCM to DSD quantization noise, looking forward to your post#2!
Apr 23, 2021 at 12:18 PM Post #5 of 187
Bit Depth
Sample Rates
The article is inaccurate and misleading from the start. The rectangles of sample showing a consistent value over the period of each sample is incorrect and misleading. Samples are values at instantaneous points in time, nothing more, a series of delta Diracs, infinitely narrow in time and with a given value. Nothing is defined about the value between each sample, so the sample-and-hold look of the rectangles should not be there.
Apr 23, 2021 at 12:27 PM Post #6 of 187
Full of typical misconceptions: staircase plot, bit depth, unrealistic dynamic range and Hi-Res BS.
If a signal is properly band-limited before sampling, it is not “better represented “ at higher sampling rate.
Also, unless you’re in space, there’s no way you’d ever utilize 96 dB of dynamic range without blowing your eardrums.
Next-up: how MQA is an absolute necessity for best signal representation!
Apr 23, 2021 at 1:05 PM Post #7 of 187
Agreed, they are Randomized with each DAC Makers keeping them secret guarded like Pepsi recipes
Apr 23, 2021 at 3:02 PM Post #8 of 187
A name Ring-DAC sounds as a member of mafia, but wait, it it will be more...
Apr 23, 2021 at 3:12 PM Post #9 of 187
Not to mention that microphones are all limited at 75Db dynamic range Max as of this moment. Yepe, silicon and wafer technologies have progressed too fast, far and beyond the other technologies.
Apr 23, 2021 at 5:40 PM Post #10 of 187
Speaking of MQA, I had a very interesting experience with dCS Bartok a few weeks before I demoed a Chord Dave, which I ultimately ended up buying. On most streams from Tidal the Bartok was playing them as 24/44.1. It was a truly bizarre experience. Just to make sure it wasn’t a Tidal only problem I plugged in an SSD drive with about 30 albums in that format with different sample rates. Same thing. The highest it would go was 24/48. That’s besides the point that the Bartok is hugely boring. I was a bit astonished that some people give it glowing reviews and even end up buying it. I was glad to have had the chance to cure myself of the itch to buy it as an all in one end game kind of device.
MQA is a totally pointless tech given that our internet speed, for the most part, is fast enough to stream high resolution music. Curiously, one website selling high resolution tracks had an MQA section. Clicking on album info was really revealing. It said something to the effect of “encoded from a 24/96 recording”. In other words one gains nothing from this format. Size savings are negligible. It’s not like we are living in the 80s or 90s where one spent a fortune on a 1gb hard drive.
Apr 23, 2021 at 6:00 PM Post #11 of 187
The interesting part for me is how the PCM is oversampled with their FPGA DSP (from what I see with JA's measurements, the filter responses in their DACs look like standard filters from off the shelf chips) with slow roll-off showing heavy aliasing while fast roll-off is not as steep as M-Scaler or Schiit's closed-loop filter
Apr 24, 2021 at 4:08 PM Post #12 of 187
I find that digital audio attracts a considerable number of "agnorants"....
"Samples are values at instantaneous points in time [...], a series of delta Diracs" - LOL, this one tops everything else in your post. You are confusing the Dirac delta "function" with Kronecker delta function, and the function with its distribution points.
For those who want to see more rectangles (I know, the horror!!!):
https://www.sciencedirect.com/topics/earth-and-planetary-sciences/analog-to-digital-converters
https://en.wikipedia.org/wiki/Analog-to-digital_converter
Apr 24, 2021 at 4:53 PM Post #13 of 187
Ring DAC is a sort of underground mafia, not listed in your link. :)
Apr 24, 2021 at 5:09 PM Post #14 of 187
You're off to a great start, @dCS James Perhaps now is the time to bring in the other dCS Engineers before this lot beats you dead. :joy:
Apr 24, 2021 at 6:06 PM Post #15 of 187
Funny, I thought we were talking about DACs, not ADC?
