Thank you very much guys for your tips, I will try this and stay you tuned!
'laters
'laters
But why would you use donut foams(a center hole mod) as they are to increase treble/lessen bass/help with clarity by letting treble through unobstructed? You are pushing the buds in the wrong direction from what you want them to be.
I am okay with denser foams and a bit of EQ which the TG38S take well enough. You might want to actually take some electrical tape and cover up more holes except for the ones closer to your ear canal to warm them up.
Originally Posted by BenF /img/forum/go_quote.gif
Now, after being packed for a few weeks with silica gel packets in a clamshell box, it sounds indistinguishable from the "good" pair. The problem was not a manufacturing defect, but an extra humidity it gained during shipping, affecting the diaphragm.
You should try this too, may be you have the same problem. If this doesn't pass in 5-6 weeks, they are defective.
Baldoor Earbell arrived today - initial impressions re: sound quality are very good. The only direct comparison I can make right now is with Sennheiser MX580 - the Baldoor is a huge improvement. Way better imaging and detail, seems much easier to drive. It provides a decent amount of bass which doesn't distort. It does sound a little bit EQ'd in the mids but it's maybe a preference thing - warmth vs. silky detail. I'm not sure it's as good as the Yuins - I can't make a direct comparison but it didn't wow me in the same way.
The package was pretty good but the supplied foams are a sickly beige colour. Not a problem as I have a good amount of black foams. Cable seems pretty good, but I'm not a huge fan of the way the cable comes out of the buds - it brushes against my earlobes in a way that I can see becoming annoying, but I can't say for sure yet.
I'm looking forward to comparing these against TG-38S and BEB 328R. I may try fixing the cable on my DIY PK2 to make a further comparison.
Pretty interesting tips guys, thanks for sharing.
If possible, may you please post a little picture(s) to see how to do that, so I will see better.
Many thanks in advance
I talked to the seller, it should be available again within the next 12 hours:
http://www.aliexpress.com/item/Croons-tingo-tg-38s-earbud-earphones-pk-mx985-a8-hifi-balanced/1428384889.html
She sold out the initial stock of 40 and has to re-stock
Does Earbell's grill look like this
or like this:
The first one is from an older version, which probably sounds different.
The new version comes with black doughnut foams.
If anyone has tried the Tingo TG800 (Sennheiser IE800 ripoffs) please let me know how they sound because I was considering them before buying earbuds from Dasetn/Aliexpress/Blox.
It's tuned to be even brighter than IE800.
