A number of sounds are used for testing, depending on what we are testing for. White or Pink Noise is used, band limited noise and multi-tone signals but probably the most commonly used are simple, single sine waves. We also use actual music recordings sometimes.Wicht sound is use for the test and how do they compare the transient ?
In the specific case of transients, we can use extreme test signals (such as a Dirac pulse for example) or again, actual sounds/music. We can compare transients with a variety of methods, for example by applying a Fourier Transform (see next paragraph) or using a null test.
That depends on what you mean by “complex to analyse”. It’s complex in the sense that you can’t do the math “in your head” but it’s relatively simple in the sense that it’s accomplished with old, proven mathematics (discovered by Joseph Fourier 200 years ago) and is easy for computers/chips to calculate.I understand that there are harmonics and combination pretty complexe to analyse.
If there is actually a difference then “yes” it really is possible to measure it and has been for many decades (for example, the CRT oscilloscope was invented in 1897, used in laboratory testing by the 1920’s and was in wide use for measuring audio performance during the 1960’s). Of course though, it’s not possible to measure a difference if there isn’t a difference!Is it really possible to mesure before and after burn in (or cable change or whatever)
Again, for many decades audio measurement devices have been capable of far more accuracy and far greater sensitivity than human hearing (by orders of magnitude) and within a range that far exceeds human hearing (again, by orders of magnitude), so if there were a difference, we would be able to find it.and be able to find difference in the range of human ears capacity ?
G
