- Sep 7, 2002
Very interesting thread. As an engineer, I have a little understanding of resonance (from the structural perspective) and how masses and their damping properties can affect response. I must say that it is interesting to read through this thread, because as noted previously, placement, amount, and size of dampers are all very important. For example, cutting up the same size of sorb into smaller pieces and then applying it may work better because of the fundamental frequencies of the smaller pieces may be more in tune with the frequencies you are trying to correct, instead of the bigger piece. Unfortunately, these things are always system-dependent to a large extent, so what works for one headphone may not work for the next. But I would be interested in knowing what size/thickness/amount of sorb would be particularly effective for 1500 Hz and 5200 Hz, for my TH900 headphones. This could also be the key to damping the treble peaks of the HD800s (without going all anax mod, etc).
I tried to get some technical specs form Sorbothane but I didn' t get the feeling that they had much to hand out. I talked with one engineer at Canjam who casually mentioned that his electronics firm used a custom ordered sorb, so I should keep after Sorbothane to give me more info. At the moment all I can say is that it's a trial and error proposition.
I have accumulated a fair stock of various sorbs that exceed my likely needs. If you or anyone else wants to pm me, exchange addresses and send me an SSA with a dollar postage I would send a sample of enough to get going on most phones. 1/8 in 30 duro self-stick seems to work with a lot of phones, although my 007A is mostly using 1/4 in.
As regards the HD 800 this is the only phone I know about which claims to be trying to solve this problem by damping. Whether they have done enough I don't know.
