Thanks Ed, i dont want to cause annoyance with this controversial subject in dogmatic crowd but if you are interested with it, it is Ok...
I have been in the situation to try and order many specimens to experiment with without previous experience about crystals....
Here are some preliminary rules i have etasblished with my experiments:
Firstly : you can put the crystals peebles in some plastic bag, or wrap them with saran wrap and scotch tape them in place....
Secondly : For the crystals in one bigger piece, the pieces must not be too big ( you can use quartz crystals between 1 inches and 2 inches (+or -) but they are very effective also in small peebles bags in place of one piece of rocks...
Thirdly :
For the green , or red tourmaline,(black tourmaline is good but less musical than the others colored tourmaline) topaz or amethyst,citrin, you can use small peebles mixed, or not mixed ( you decide by experiment) in a small plasctic bag.
Mixing 2 species of crystals make some sort of equilibrium and compensation, and i now mix 2 species often or buy them naturally bond...Quartz can be chemically bond with a chemical element like fluor for exemple : fluorite, or fuse with another stone: amethyst quartz crystal, and it is always good....Only pure one kind of rock stone amethyst ,topaz,etc will be good or some pack of little peebles mixed or not mixed is also good...
the colored or phantom quartz crystals or any quartz fused with other chemicals element is very good and better than only white quartz...White quartz are very powerful and can be too much harsh sound if use downstream in your system... I will divide the use of crystals in 2 location classes
UPSTREAM : White quartz crystal or better any colored quartz mixed with tourmaline or any other species you want to experiment with(very powerful, perfect for cleaning the electrical line)
-- On the central electrical panel of your house on the breaker implicated with your audiophile room..
-- on other breakers in the audio room or before it...
-- on the power cord of the power conditioner...Or on top of the power conditioner also...
-- ..................................of the amplifier.
-- ................................ of the dac
-- on the power supply in and out.
-- on the wall outlet in your audio room where all audio is connected.
DIVIDING LINE : power conditioner or power strip
DOWNSTREAM : phantom or ghost quartz green or red Tourmaline, topaz or amethysts, ruby, even jade, or agathe (these crystals are more subtle and more musical than the white quartz, because of that better place in downstream with interconnect etc)
-- Principally all interconnect between all pieces of gear,in and out.
-- on top of the transformer of the amplifier, or on top of any transformer...
-- on the in and out of the battery of my dac...
-- On the power switch of the amplifier or pre-amp or of the dac etc, one little peeble ( i use blutak for that)
-- in the rear port hole of my speakers, or inside it if no port hole, or on the speakers cable...
-- on the headphone out or in the cable, or inside the headphone ( i will try that with some peebles)
In general white quartz is better upstream....It is cheap and easy to buy... try only one on the breaker and enjoy...In the first day i try that...After that i dont hesitate to order all other specimens...The list of rocks i give here is not exhaustive, but you are more safe to try that for a beginning... I have order lava rocks to try and mix with some other rocks, but i cannot recommand that because i have not listen to that actually.... All others name of rocks i speak about here are good choice to experiment with...I dont know for all the other possibilities ...
Imagine the number of locations possiblities in your system, (15, i think in mine), multiply that by 6, 7, or 8 different specimens of rocks at different possible places, the combinatorials results are very big numbers , hence i dont know the final optimal disposition... Plenty hours to play with these possiblities...
And i will say that,(at the risk of opinionated people mocking me) NO one rocks sound exactly the same in my systems, like no tubes sound the same, and act differently in different place, often this is subtle, often this is not subtle and very audible...the upgrading effect is not small, but remember that my system is sorbothanized , the listening of the many experiments is easy with this sorbothanized. system...At the end the effect is 3-d imaging on a superior scale than with only the sorb.and a better dynamic all across the frequencies board...To obtain that each stone will act on his own, and complement the others stones, at the end of the road an optimal equilibrium, without coloration of the sound like with some tube, but with only a more natural timbre and soundstage...
These are ONLY my temporary conclusions, BUT the change in sound were so evident and when rightly place so great in the speakers or headphones that this is not even comparable to the change of tubes in my Ember amplifier,( i dont use it now, i prefer my Sansui by a long margin) hence no small upgrade...You must experiment to discover the right materials at the right place in your system...If you dont use sorb. in all your gear the change will be less spectacular because sorb clean vibrations and make easy to listen the sound effect resulting from the cleaning of EMI ...
Without consideration of price ALL audio products are plague by vibrations and EMI, i know now that mid-fi system can sound like, or almost like, hi-fi system modulo sorb. and crystals...
P.S. to answer the question where to buy? Simple Ebay auction or aliexpress, i bought all from china because it is inexpansive,and i choose the company that charge zero postal fees... There is good deals on the auction system...
