- Sep 7, 2002
Got it fixed rather quickly. I will be bringing a meter, soldering iron and some tools to Canjam, along with some sorbothane.
How did you repair your 007's cable? Also, does the thickness of the sorbothane matter?
Bon voyage and happy meeting, greeting and listening.
p.s. don't go sticking any sorb on the Hifiman HE-1000 without Fang's permission....
There appears to be damping under the band. Could it be sorbothane? If you have one to hand possibly you could have a look.
I think it's the cheese from a MacDonalds junior cheeseburger......
For the other side, I unsoldered the wires at the junction in the earcups just before you get to the drivers. You would have to be damn careful soldering the drivers because you could easily melt the mylar so this is why I think Stax uses this junction ploy. It is also necessary to identify which wire goes where so you can put it all back together. Then pull the whole cable out of the strain relief ( I still had to cut off the bottom section of the strain relief to get the cable to move easily. Then cut off the whole cable below where the break is, reinsert the cable through the strain relief, strip some cover off the wires and solder the three wires back on the junction. Obviously this shortens the cable an inch or two.
I never understood why people here talk about blind testing of tweaks, cables and the like but not when it comes to picking new equipment. Can you really say those new $1500 cans were objectively better than the $500 pair.
We also chronically misue the term double-blind. That refers to a type of testing in which neither the testor nor testee know what is coming next.
Yes, because there's 'better' and 'different'. I only listen to classical music (am a musician), and can absolutely hear when a component screws up the sound of a cello, piano or orchestra. Everything does, except Stax which is the only component which gets it to the point where I can't distinguish from reality. Then there's different, which are changes in tonality and presentation usually. For example, the 4070 sounds "flatter" and "thinner" than the 009 - but it's just as real. It's no different than listening in a different concert hall.
Finally there are imaginary differences. I notice they seem to happen most often when I first hear something, and after listening for a while. The first bit is probably a hormone rush from trying something new. The later bit is my brain rewiring itself to the sound. The latter effect happens so frequently is the reason we need blind tests.
Calibration is also needed. I calibrate myself against my concert grand in the living room, to the sound of a recorded grand.
Finally though isn't it odd you complain about how people say one component is better than an other, when you are promoting sorbothane as a big improvement?
Which is why I called it a blind test.
I have spent 9 hrs today at Canjam. I was able to do some A/B demos with my two high bias Sigmas, one damped and the other not. Most people said the differences were clear. Maybe 2 people in the whole said they couldn't tell the difference.
My basic test is to listen to familiar music and determine if anything sounds different or better.
