"Damping" and "resonance" mean several different things as applied to headphones and speakers. "Damping" in my use refers to the reduction of vibrations in headphones by materials (in this situation, sorbothane.) What vibrations? In this context we are referring to the vibrations passed to the earcups and other parts of the headphone by the movement of the driver. Newton tells us that there is an "equal and opposite" reaction to the driver's motion. That seems to indicate that the energy getting into the earcup is equal to what is making all the sound we listen to and thus there is considerable potential for distortion of headphone sound by these vibrations.
Here is a definition from Wikipedia:
"Damping is an influence within or upon an
oscillatory system that has the effect of reducing, restricting or preventing its oscillations. In physical systems, damping is produced by processes that dissipate the energy stored in the oscillation"
How does sorb dampen vibrations? According to the company by converting the vibrational energy to heat. Again according to Newton, energy cannot be created or destroyed but it can be turned into some other form of energy. I would assume that the vibrational energy getting into the cups normally dissipates, probably as heat, but probably a bit slowly. What I think the sorb does when added to the cups, is get rid of the vibrations faster so they has less impact on what we hear.
Damping also is used to refer to the use of foam and other materials behind the drivers which is used to tailor the sound. Thus my SRXIII's have a wad of fiber material behind the drivers. The 007's don't. Presumably these materials behind the drivers dampen specific frequencies.
I have also used the term "resonance," sometimes when I probably meant vibrations. Resonance refers to the tendency of physical objects and airchambers to vibrate at specific frequencies. Thus a headphone has a specific frequency which it will tend to maximally vibrate at. soren-brix, above, also notes that individual parts may have their own resonant frequencies and that for the 007 arc assembly that seems to be about 150Hz.
A definition from Wikipedia:
"In
physics,
resonance is the tendency of a system to
oscillate with greater
amplitude at some
frequencies than at others."
In these experiments the sorbothane appears to be dampening vibrations, including resonant frequencies although exactly how much of what frequencies I don't know.
I am uncomfortable in these discussions because I have no background in physics other than some high school and college classes, nor am I a mechanical engineer. My doctorate is in experimental psychology in perception, including the study of vision and hearing. I also spent 5 years doing post-doctoral work in a Department of Electrical Engineering but I have been a lawyer for the last 25 years. But none of this background really prepares me for this specific topic. However I have observed the various odd things about sorbothane and headphones described above and am trying to make some sense of it all. Anyone else is free to have a go, preferably after having tried some sorb mods themselves.
soren_brix "no japanees say we "goofed" ... would be kamiaze ;o)
Hopefully no-one at Stax will fee the need to commit ritual suicide because we criticize their design of the 007.
