ab initio
- May 1, 2013
Equations are nice an all, but Tyll has nice webpage on how planar magnetics work. I sense that practicality of how both work will be more insightful.
http://www.innerfidelity.com/content/how-planar-magnetic-headphones-work
I'm quite familiar with Tyll's page and his and others articles on orthodynamic headphones. They do a nice job about doing a show-and-tell of the inside of an orthodynamic headphone and showing how the arrangement of magnets and etched traces differ from the classing driver layout. It's also nice how they explain what issues these types of design changes attempt to address over the classing dynamic driver design.
Aside from that, the article does nothing to address how "damping factor" affects the driver's fidelity. There's a quick snippet that gives some wishy-washy discussion (without any references) that claims orthos suffer from a lack of damping (from what i can tell, based mostly on the fact that modders focus a lot of attention on adding damping materials to the headphones---which is about all modders can do to headphones in the first place). The claim is in direct contradiction with one of the articles linked at the end of his post (the wisdom audio article) which claims that orthos naturally have very tight control over the motion of the diaphragm (This article that is nothing more than some advertising doesn't have any sources cited for these claims either). Who to believe?
It really doesn't matter. I performed the relevant analysis above, all we need are typical headphone parameters for orthos and we can quantitatively assess the importance of damping factor.
^_^. ab initio you killed us here.
about the dynamic vs planar, there are simply too many reasons for differences to just try and deduce a behavior from the dynamic drivers IMO.
the magnetic field is different and if the principles obviously remain the same, as I said, the fact that the magnetic field can be the same in all positions with a planar has to impact the capacity for control. but it needs more power to work the same, so that means more opposing force... it's hard to get a clear view of the entire system(at least for me).
the weight and flexibility of the moving part is different too, so the mechanical damping might not be the same as dynamic drivers(I say might but I'm pretty sure it's not).
also the air flow has to be massively impacted by the magnets on each side that are obstructing the path. I'm not sure you can assume the electrical damping to always be of same importance be it to get the membrane at a precise position, or to make the driver stop.
I'm sorry I can't follow you on the formulas, my last years at school where about optic and photography ^_^.
maybe someone can kidnap Tyll, I remember a video where he hadbrokenopened a planar. and he often mentioned talking a great deal with the audeze boys.
In my analysis above, I'm not trying to capture higher-order effects that depend on details like whether I have a dynamic driver with a suspended speaker cone with a coil centered around a magnet stator vs having an array of magnets with traces etched on a membrane. I was addressing the operating principal of these drivers and their most basic level by reducing them to an approximate mass-spring-damper system and corresponding electrical equivalent.
The result of the analysis is that the speaker system is defined by it's mechanical properties, M, C, and K, and its electrical properties, Zeb, and the electro-mechanical coupling which is given by B*l. These are the properties that describe the system whether the speaker is "dynamic" or "orthodynamic". The fundamental equations are exactly the same. This is why "damping factor" applies to orthodynamics in the exact same way as it applies to dynamic drivers. This is what I've demonstrated in my previous post. My analogy here is that of classic bicycles and recumbent bicycles. Both operate by exactly the same principle: you get on and pedal, turn the steering wheel to steer and squeeze the brakes to stop; however, the layout is quite a bit different and results in some key performance parameters being a bit different (like aerodynamic drag). Yes, orthodynamics are layed out differently than dynamic drivers and some of the values of key parameters are different, but its the same underlying physical principle at play and the governing equations are identical.
What everybody else here seems to be arguing is that between typical "dynamic" and "orthodynamic" drivers, there are differences in the constants that define the system. This is certainly true. M, C, K, B*l, Zeb, etc. are all different between the two different types of designs and even among the various individual drivers within each class. I am not arguing against this at all! These are exactly the types of parameters I'm asking the community here if they can give me typical values for the each of the types of drivers. The difference in these parameters between dynamic and orthodynamic drivers doesn't change the fact that the equation governing how "damping factor" influences the driver is exactly the same. What the differences in these parameters will do is change how the impact of varying damping factor compares in size to the other forces at play in the transducer's response. I've given you guys the fundamental equations, all you guys have to do is tell me what the typical values for each type of driver are and we can calculate it directly.
Guessing that the layout of the magnets makes dynamic drivers susceptible to damping factor issues where orthodynamics are immune is no more helpful to this discussion than guessing that conductor material makes copper cables susceptible to transmission line effects where silver cables are immune is to cable debates. (and I know how most of you feel about that! )
I haven't said anything in my arguments to claim that orthodynamic drivers rely on electrical damping for proper function. I'm saying that the governing equations for ortho and regular dynamic drivers are exactly the same to zeroth order. I'm trying to fix the common misconception that somehow orthodynamic drivers are inherently immune to damping factor issues because they have purely resistive impedance. As far as damping is concerned, there is zero relationship between the frequency-dependent impedance character of a driver and whether or not is it susceptible to damping factor issues.
Cheers
