tiagopinto
Ah crap, bit far for me on short notice but it does mean there may be others with sample pairs, think it's time I contacted some shops!
So I did go and try the iO-6. In one word, stunning!
The shop had a few Grado’s (I tried the RS2e and the GS1000e) and Audeze (I tried the Mobius and the LCD-2 Closed Back).
Basically, I wanted to go up before I came down. I also had my HD 280 Pro on hand, for the reverse process.
Honestly, I found the Mobius too much in your face and loosing control. They do play loud but... not my thing. And, as I’m not a gamer, I’ll never ever use what they are ready for. Don’t get me wrong, their sound is good but...
At exactly the same price point are the iO-6. I’m glad they come with a carrying case (the iO-4 don’t) and, even being almost “straight out of the box” the sound was amazing.
The highs are present and detailed without ever being harsh.
The mids are forward and not exaggerated.
And the lows are deep but not thumping.
Straightforward, true and very enjoyable.
I couldn’t test the ANC very well but it’s definitely there. Off, Transparency (outside amplified) and On modes.
Pairing was very easy both with an iPhone and a Hauwei (which was definitely not the case with the Mobius) and I did move from room to room leaving the phone behind and the signal never dropped. I didn’t test videos and possible latency because we had little time and I wanted to focus on the music. So I tested them mainly listening to this:
And they played every genre flawlessly which is an enormous plus for me.
The build quality seems very, very good. The earcups are round and not elliptical, which I would have preferred to fit my large ears. But still comfy due to the good choice of materials, leather and cushions. I don’t know if they will have an accompanying app but... do they need it?
You can do almost all with the very welcome (not tactile but soft, perceptible and effective) buttons, less prone to accidental touches. I didn’t test phone assistant features.
Are they a winner? I don’t know. I honestly want to go back and retry the B&W PX. They were that good. Are the iO-6 just better?
Overall I think they are transparent with great instrument separation, a good soundstage and the layer detail and fidelity is astonishing.
Hoping to hear from you guys what you think!
Cheers!
