Epoch
- Apr 27, 2006
Well, if you are waiting for some more information, the Reference 7 loaner program should start seeing results in the next couple of weeks as the DAC was already shipped by Audio-GD. So if you are looking for more feedback and input on the higher end models, that should be forthcoming.
Disclosure/setup
1) I use a high end power supply in my computer that costs almost as much as the Essence STX because it provides cleaner power than almost every other power supply on the market so maybe my performance is slightly better than normal
2) I did some A/B testing just to make sure nothing was broken and to see if I could hear any major changes after letting both the amp and the DAC warm up for about an hour and a half to get up to normal operating temperature.
3) RCA interconnects are used for the Essence STX and ACSS for the DAC. I am testing my gear, not some theoretical setup that uses Audio-GD ACSS gear but only uses RCA interconnects.
4) I am using my HD650s for this, as it is what I use 99% of the time I use headphones.
5) The DAC has been used for about a dozen hours before writing any of this.
As for the DAC19DSP vs the Essence STX, the difference to me isn't large in any one area. As always though, large is not a standardized measure, so good luck with relating it to your personal unit of large.
I didn't expect huge differences, its just minor details that seem to have changed. Basically, things are a little more detailed as compared to before, its nuances that are improved, the little things. The soundstage expands a bit further outside of the head, and sounds that are centered don't quite sound the same as before. They were a little more of a blob in the center of the head before, now it sounds a little more spacious. To clarify that last point is somewhat difficult to articulate, its a change from being slightly snug to properly adjusted. With the larger soundstage, sounds just fit into position better, instead of being nudged into the soundstage to fit, they are just there. That could be the DAC and the minor details it brings out, or it could also be related to having a dual mono design.
The best way that I can think of putting it is that you have a nice clean metal surface, but along an edge there is a slight burr. You don't notice it until you run your hand along it, but its there. The DAC smooths that burr, same edge, just a little better for finish. That is what I am getting after about a dozen hours of use, same sound, nicer finish/detailing. I can't think of an audible issue that is there that didn't exist before, its getting more of what you already have.
I will probably notice more later, and would be better able to notice differences after using the DAC for a few weeks, as I have always found that it is easier to know what you are missing by getting used to it being there.
In reference to one of your earlier comments about sound signature and EQ, these differences aren't something that I think EQ can do.
Somebody else may hear something else, but that is what I get from my purchase. Your results may vary, your equipment does vary, and your goals may vary, so I can only speak for myself. As to the value of these minor details, that is also a personal preference, so I sadly agree with earlier comments that you need to hear it and try it to know if you will like it. As long as you have reasonable expectations though you shouldn't be disappointed.
In all fairness, its not like the Essence STX is a poor performer, it just doesn't quite compete with the DAC19DSP. For what it is and what it costs, it does an excellent job.
I don't have experience with higher end gear, so somebody please correct me if I am wrong, but I would imagine that the purpose of a higher end DAC is to resolve and accurately present ever smaller details and nuances. That would lead to the assumption that the differences to get smaller, as that is the goal. That isn't to say that the differences become more inaudible, as I can't attest to that, more a suggestion that it becomes more of a complete presentation of what was recorded.
Since you are looking for something much more expensive and higher end than what I am using though for a DAC as per your budget, wait a little while before you make a decision. There should be a lot more exposure of the Reference 7 due to it making the rounds to some members here for review, so if I were you I would wait to see some results from that.
Disclosure/setup
