replytoken wrote:
Congratulations on your decision, Thomas! I hope your new purchase will play well in your system.
Thanks!
Given your choice, I was wondering if you had considered the Music Hall 25.3 DAC in your search process?
No I hadn't. Why? I didn't know of the Music Hall 25.3 DAC until you mentioned it here. For purposely unstated reasons, I gave up on Audio-gd. Because of this, I decided to continue checking out the Buy/Sell forum and the Stello DA100 Signature came up for sale. My opinion, for the most part, design nuances aside, from what I've gleaned, at any equal price point, DAC's are more neutral than active. So I read reviews on the Stello DA100 Signature. Nothing glaring jumped off the reviewer's pages and nothing in the reviewer's nuances set off my warning bells. It looked good on paper, looked good as a picture on a table, so at the price of used, I took a flyer.
It was one that I had initially considered, and given how you have described your music and listening preferences, I thought it might have been of interest to you. BTW, I decided to go budget and buy a NuForce uDAC-2. Hopefully it will meet my current needs, and it will buy me some time before I decide whether to spend some additional funds on a DAC.
I'm sorry that I didn't read up on the Music Hall 25.3 DAC you mentioned. There are so many choices. NuForce is well respected so I'm sure it will do what you're wanting. Me? I'm pretty much clueless so all I can do in encourage out of ignorance.
I did a quick check on the Music Hall 25.3, and for the price difference, if you haven't already purchased the NuForce, I'd encourage you to step up to the Music Hall 25.3 for added connects and features over the less expensive NuForce unit. A suggestion, check out the Buy/Sell forum as there are deals (twenty to fifty percent off) to be had from folks going through a round of upgraditis.
Happy listening,
Thanks! Looking forward to hearing the differences and here's to there being a positive outcome on both our parts.
An aside, talking to my wife, I had an interesting thought. Reviewers will write about how a hundred dollar DAC is equal to three hundred dollar DAC's. I carried this forward to, a study should be done following the compared DAC's. If a reviewer names a DAC the lesser value DAC is equal or better than, then the more expensive DAC should be vetted. And any DAC the three hundred dollar DAC is listed as being better than, should be vetted to see what more expensive DAC it is better than. By comparison, the extension of the idea is, that in the end, if all is or were true, then the hundred dollar DAC, originally reviewed, would be better than the most expensive DAC reviewed when the chain of comparisons finally ends.
Hmmmmmmmm!
Yes I know, on it's face it's ridiculous but to those who will, before discounting the above thought, think about the validity of the logic. Sans any listening standards, isn't this what happens when the voice of subjectivity takes over the voice of reason? As the above harkens back to the OP title:
"DAC's. When is good enough, good enough?"
(Yes, I know, cable debate.)
