Digital Head-Fi (mis)adventures continued:
I've always been a plug'n'play guy using my iPod Classic with dock & DAC (which switches sampling rates automatically) so only now have I really looked into the computer audio thing, via my Macbook.
So far I have for instance found out that it won't automatically switch sampling rates depending on the source, regardless of the player (never noticed it with the Bifrost & D2 since they don't display the incoming sampling rate). The DacMagic 100 never switched, neither via optical in (always at 44.1) or finally USB (always 96): turns out you have to use the Audio Midi Setup app in OS X to manually set things, which then switched the DacMagic 100's incoming sampling rates correctly (both via optical & USB). Easy to use but a bit limited: you'd have to manually switch it everytime you want to match the source sampling rate of the album you're playing, and either way it's limited to 96kHz max. (The D2 actually seems to be limited to 48kHz via USB)
I'm dealing with enough computer issues (all OSs) at work all day, so I really don't feel like jumping through the hoops to get Windows with custom drivers going (in Bootcamp for direct hardware access I guess, since virtualization passes through OSX to access the ports)
So unless I can get 192kHz support going in OS X in some way, testing 176kHz is pretty much out of the window as well, sorry. If I ever have more time I'll look into it.
If somebody else wants to give it a go, I rummaged the interwebs to find some 24/176.4 samples that are available as of this afternoon:
http://www.onlythemusic.com/Downloads (Despite the vague blurbs, the downloaded WAV files are really 24/176.4, I played & checked them, just can't output them at the source sampling rate to my DACs)
