Originally Posted by ROBSCIX /img/forum/go_quote.gif
You should read some of his posting in the other forums.
According to him:
You can use onboard soundchip with ANY cheap cable, connected to any cheap amplifiers and have the best sound humanly possible!
Also, ALL headphones do not require an amplifier at all...
He has a point, but really he's taking it a bit to far there. Plus he's just being obnoxious. I believe in policing your own, partially agree with his position, and would like to state it in a more civil manner. Even if he needs to be denounced, there are some nuggets of truth that need to be dug out and properly presented.
In reality you can take any decent soundcard, any decent cable, any decent amp, and get 90-plus percent of the SQ of a money-is-no-object system, transducers and source held constant. It is easily possible to make DACs (Yey! finally back on topic!) fully transparent. Once a component is transparent, you essentially can't tell that it's there. It doesn't change the sound in any audible way. This also means, by definition, that one transparent DAC is sonicly indistinguishable from the next.
If you're after euphonics and not transparency, then that's ok too. One of those Audio GD DACs might be for you. I know I'm not always after transparency. I wouldn't own any tubes if I was, but my personal opinion is that adding more color to the DAC circuit itself is largely counterproductive. Between combinations of headphones and amps, and opamps and tubes within the amps, along with various DSPs, software or hardware, I think there are plenty of other more controllable ways to add whatever color you want to your sound.
I'm not trying to tell people that they shouldn't buy intentionally colored DAC though. I'm not trying to force anyone to do it my way. I'm just saying that its quite possible to get a completely or very nearly completely transparent DAC for not a lot of money if that's what you're after. In addition, it shouldn't be surprising that DACs which are transparent, or close to it, aren't easily distinguishable. If you're after transparency, an X-Fi, Xonar, HT Omega, or a semi-pro DAC of some kind is just about as good as it gets. If you're after something else, then well, the sky is not even the limit. I don't know if there is a limit at all.
Also,
that video in his sig is actually quite good.
